1 members (Pyewacket),
227
Topics49,911
Posts838,147
Posts: 270 |
The Morgan is new and coming up for its 1000/3 month service in July, done 400 miles so far in between the showers.
I've read all the threads on here and taken the advice of procuring a nice twin valve Wanner for the odd 1000 mile top up should I need to.
Suggestions for grease seem to be either the Lucas Red stuff or Comma Moly.
Just thinking though, is it probably best to find out what Oakmere will be using (as they will be servicing the car whilst under warranty) and fill the Wanner with that instead of possibly mixing and matching? The car will be very lightly used so I don't think it's a huge issue anyway but just curious what other guys do and reckon.
Cheers.
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
I'd either do what you suggest and find out what Oakmere will use or tell them not to touch the kingpins and you'll do it yourself.
1972 4/4 2 Seater
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
I use whatevers cheapest of the correct grade from my local lubricants suppliers. Job done!
Arwyn
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Arwyn After faffing about with various sorts & colours, this is about right now.. Life is too short to argue about oils & greases I think.
Posts: 2,781 Likes: 5
Posts: 2,781 Likes: 5 |
The bottom line is it won't matter. I've used all sorts and have come to the conclusion that grease is grease. Just do it little and often and you'll be fine.
Steve 2008 4/4 1.8 Duratec
Posts: 543 Likes: 2
Posts: 543 Likes: 2 |
Throughout 40 years of Morgan ownership I've always used Castrol LM.
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
Castrol LM or red & tacky
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
used all sorts of grease for forty six years , does not seem to matter
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
I use whatevers cheapest of the correct grade Life is too short to argue about oils & greases
it won't matter. Just do it little and often and you'll be fine. These. Definitely.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Throughout 40 years of Morgan ownership I've always used Castrol LM. + 1 every 700 miles, 32k and no play
