0 members (),
368
43
Topics48,345
Posts813,037
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
Tarka is sorted, hideous squeal eliminated. I'll collect the car on Friday.
The source?
Nothing that we considered or discussed.
One of the auxiliary devices driven from the front of the BMW N62 engine is a vacuum pump. This provides vacuum for the brake servo and on a BMW car, other functions: there are 2 vacuum ports in the pump. .
On a Morgan Aero the second vacuum port is caped off.
The cap split: what we could hear is air being sucked through the cap.
Replacement? Less than £5.00 Labour? 5 .5 hours.... Bonnet, Cowl and 1 wing off. The pump is low down on the off side.
Williams discussed this issue with Morgan Motor Company. It is a "known but rare issue" !!
So, now all with the 4.8L BMW motor know. If you car starts making a noise like a squealing fan belt, which starts intermittently but becomes continuous, it is very probably this problem. Of course, it isn't a BMW issue, but a Morgan one.
Posts: 3,383 Likes: 12
Posts: 3,383 Likes: 12 |
Glad to hear it's fixed Peter and thanks for sharing, that way we all learn.
Colin,
I am somewhat relieved, although I'll be relieved of more than a few ££!!
Posts: 431 |
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
But... 5.5 hours labour! All down to access (lack of).
Posts: 4 |
Hello Peter,In my post I mentioned the vacuum pump,so you have to read your answers to your posts saves you a lot of money.Paul
Posts: 5,653 Likes: 4
Posts: 5,653 Likes: 4 |
Simple fix by the sounds of it. Pleased it's sorted.
Martin (Deano)
Hello Peter,In my post I mentioned the vacuum pump, so you have to read your answers to your posts saves you a lot of money.Paul Paul, lesson learned, don't assume the obvious. I didn't even know the BMW had a vac. pump driven by the engine. Good to have someone here who know about the mechanical side of the BMW B8 in our Aero based cars. I see you are quite new here, so a belated "welcome!" Peter
Posts: 35,776 Likes: 468
Posts: 35,776 Likes: 468 |
Glad you have this sorted and not too exorbitant.
Posts: 5,587 |
Thanks for the heads up regarding this Peter , will be less fearful when/if it starts shrieking at me !
