Topics49,861
Posts837,534
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Spent a couple of hours prepping the Healey for its run to the IOM this Friday. Topped up the steering box ( where does the oil go as it has no leaks?) and idler, greased the front end, levels and pressures checked, a little oil in the dash pots, some chain lube on the leaf springs and a few spares chucked in the boot along with some fuel! Sorted! Didn't fuss too much with the paintwork as its already well waxed and anyway looks like it could be a rainy few days. It'll be a 4am start and a good 4 hr run up to Liver bird land, avoiding motorways to meet the other Wild Moggers and IOM here we come!
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Have a great trip chaps
Posts: 6,538 |
+1 have a great time all. look forward to seeing the
Neil
Posts: 28,900 Likes: 352
Posts: 28,900 Likes: 352 |
+1 have a great time all. look forward to seeing the Yes indeed!
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
Good luck guys. We had a great time on the Isle. Very car friendly folks & a really lovely place.
Posts: 37,418 Likes: 978
Posts: 37,418 Likes: 978 |
Spent a couple of hours prepping the Healey for its run to the IOM this Friday. Topped up the steering box ( where does the oil go as it has no leaks?) and idler, greased the front end, levels and pressures checked, a little oil in the dash pots, some chain lube on the leaf springs and a few spares chucked in the boot along with some fuel! Sorted! Didn't fuss too much with the paintwork as its already well waxed and anyway looks like it could be a rainy few days. It'll be a 4am start and a good 4 hr run up to Liver bird land, avoiding motorways to meet the other Wild Moggers and IOM here we come! Have fun "invisible man"  .
Posts: 14,009 |
Don't forget your map of all the fuel stations Steve 😈 See you for breakfast on Friday!
Cleaned the car, checked the coolant.....the radiator has just a very slight weep, everything else done when serviced last week. I've given up on the idea of fitting the Minilites for the trip. Tried a 195/65/15 tyre on one wheel. Plenty of clearance in wheelarches etc but the wheel will not fit easily into the spare well.....touches body at bottom. Weird as I looked at Ian's Plus4 and he has no problem there. So may have to go for 205/60/15s as the standard wheel. Jury is out on that at moment. Also the rear studs look a tad short, the Minilites must have a thicker centre than the Morgan alloys.
Posts: 22,362 Likes: 353
Posts: 22,362 Likes: 353 |
Could you have some sleeve nuts made up, and open up the holes in the Minilites?
Posts: 14,009 |
Simpler to fit longer studs Dave.
I hope SBM's packed his Bonnet polish 😋
