3 members (MartinB60, TBM, Image), 131 guests, and 63 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,427
#457846 28/06/17 12:08 AM
WW1 ACE Offline OP
I saw a post where somebody in the US changed the rear red fog light to white so that it acts as a white reverse light when you put the fog light switch on. But has anybody actually rewired the rear fog light so that when you put the M3W in reverse it actually turns the light on?
If so, please also let us know if you did anything with the fog light wiring, or if the fog light switch is now just a dead switch.
2017 Morgan 3 Wheeler -BRG Shark
2008 Lotus Elise California Edition -Red
2009 Land Rover LR2 -Black
WW1 ACE #457847 28/06/17 01:11 AM
When my car is finalized at the dealer, i have asked them to swap it out also.
The switch from the gearbox is already fitted. Just change the light and hook it up.
WW1 ACE #457864 28/06/17 07:35 AM
Yes have fitted automatic reversing light although retained fog light in original position. The wiring loom already has a gearbox switched feed to a four way connector behind fog light to supply both or you can choose one or the other. It's plain dumb not to use existing dedicated feed if you want a reversing light.
Check out this thread.
WW1 ACE #457935 28/06/17 03:22 PM
I have mine on the fog lamp switch. Now that i know how easy it is to swap it to work as a true reversing lamp I may move the wires.
kirkusblog.com
1952 Ford 8N
