Topics49,866
Posts837,595
Posts: 53 |
Dear all
I have just collected "Madge" from having a "bit" of a paint job done (quite a bit really!). She looks wonderful. However, the technicians in carrying out the strip down, unfortunately, managed to badly damage/ smash two of the oblong warning lights.
The lights between the Speedometer and the Rev Counter are:
Top Row, Row 1 - 2 oblong lights side by side - Don't know what these are for and can't recall them ever being illuminated. Confirmation requested
Row 2 - a single oblong light which is the Handbrake. OK Working
Row 3 - a single oblong light (Broken) which I presume is the Ignition Light but no illumination. Confirmation requested
Row 4 - a single oblong light (Broken)which is the Blue Headlights ON.
And finally
Row 5 - 2 oblong lights side by side which are the L and R Indicator Lamps which are functioning and OK.
I would be grateful if I could get confirmation of the lights as requested and if you happen to know the part numbers as well that would be great. I presume that Melvyn R is a good source?
With Kind Regards
Vladek and "Madge"
Posts: 27,814 Likes: 749
Posts: 27,814 Likes: 749 |
Vlad, glad you upgraded the paintwork, sorry about the lights. HoE also I think do / did a stainless upgrade for the them. Might be worth having a look.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Like you I don't dont know what the top two are as I've never seen them on so guessing they could be oil level warning or engine problem
Next down is handbrake
Next down battery/ignition
Next down main beam
Then the indicators
Posts: 37,429 Likes: 978
Posts: 37,429 Likes: 978 |
Mine is a 1999.
Top two green indicator repeaters.
Ignition warning light.
Headlight main beam.
Brake warning light Handbrake or low fluid.
Inertia switch warning light (Yellow)
Now this is odd I've looked in the original manual and it only mentions one of the top two being the Inertia switch warning light (yellow) Doesn't mention another
Posts: 53 |
Gentlemen
Thank you for the contributions so far.
With Very Kind Regards
Vladek and "Madge"
Just found this website that is advertising the warning lights http://www.charlesworthmouldings.co.uk/i...orig&id=144
They seem to have them all at £12 each
Posts: 53 |
Thank you Stewart. I'll pass this info onto the firm that committed the outrageous atrocity to Madge. (Tee Hee)
Vladek and "Madge"
Now this is odd I've looked in the original manual and it only mentions one of the top two being the Inertia switch warning light (yellow) Doesn't mention another I have copied my manual which I used to answer the query with as it's tinkling down here.
