Topics48,362
Posts813,325
Members9,215
Posts: 1,613 Likes: 22
Posts: 1,613 Likes: 22 |
I fully intend to change the rear light arms. Does anyone know the price of the standard light pods?
If they are the same as the the front they will be easy to modify. The fronts are mounted on a length of studding with a hole down the centre of the studding for the wiring, the pod and the circular sleeve slide over the studding and are fixed with a nut inside the light pod.
Posts: 46 |
If they are the same as the the front they will be easy to modify. The fronts are mounted on a length of studding with a hole down the centre of the studding for the wiring, the pod and the circular sleeve slide over the studding and are fixed with a nut inside the light pod. I beleeve the original studs are still there, with an added extention,easily removed. just coil up the excess wiring if neded for MOT.
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
That is more annoying to me than the rest of the mods forced on Morgan by the EU. I do wish people would stop blaming the EU. Apart from any other thing the UK still has a vote in the EU Parliament and members in the Commission. Vehicle passenger and pedestrian safety is a progressive thing. Most of these changes are not dissimilar to the Australian Design Rules compliant model. It is amazing to me that the M3W was able to be released in its original form as it is, without any doubt, a 3 wheeled car, not a 3 wheeled bike. Even without the EU UK regulators would sooner or later require a tightening up on many of these items. That big hot lump of metal out the front was always going to be a pedestrian hazard and and one can understand the reason for changes to the lighting positions. The M3W is a very retro vehicle. Just think how many classic vehicles would be impossible to register today, under the rules of any country, for reasons of safety.
Posts: 402 Likes: 3
Posts: 402 Likes: 3 |
I'm visiting the factory on Monday, will hopefully (?) see it then.
Tim
Posts: 1,774 Likes: 19
Posts: 1,774 Likes: 19 |
...That big hot lump of metal out the front was always going to be a pedestrian hazard and and one can understand the reason for changes to the lighting positions.... While I don't blame the EU, it is funny that the cooling fins are "too sharp" ... pretty sure that will not be hurting a pedestrian much vs the heat and mass of the engine!
Posts: 1,490 |
...That big hot lump of metal out the front was always going to be a pedestrian hazard and and one can understand the reason for changes to the lighting positions.... While I don't blame the EU, it is funny that the cooling fins are "too sharp" ... pretty sure that will not be hurting a pedestrian much vs the heat and mass of the engine! And the Feds here in the USA are requiring all cars to have the "bright pack" (chrome jugs), also because the standard jugs are too abrasive.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 1,015 Likes: 1
Posts: 1,015 Likes: 1 |
And I wonder if the increased ride height has once again worsened the Bumpsteer problem, seeing as the 'fix' up till now (Empire aside) was only to minimise the impact by getting the steering arms horizontal again.
Such a shame....
Posts: 136 |
...That big hot lump of metal out the front was always going to be a pedestrian hazard and and one can understand the reason for changes to the lighting positions.... While I don't blame the EU, it is funny that the cooling fins are "too sharp" ... pretty sure that will not be hurting a pedestrian much vs the heat and mass of the engine! And the Feds here in the USA are requiring all cars to have the "bright pack" (chrome jugs), also because the standard jugs are too abrasive. HUH?? My USA 2017, delivered in late April, doesn't have the bright pack.
1959 4/4 - sold 1957 +4 - sold 2017 M3W - sold
Posts: 836 |
rear lights configuration confirm that all minor fender benders will leave you without rear lights.
Posts: 2,539 |
Heck just passing pedestrians will accidentally snap those stalks
