5 members (asbojohn, Colin_Mackay, Bunny, Soleng, Alan Patterson), 330 guests, and 51 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
Page 10 of 11 1 2 8 9 10 11
Originally Posted By Hamwich
Yes, I understand the purpose, but I can't figure out how this rotation is supposed to be able to occur. The inner face of the thrust washer bears against the inner ring of the bearing, which doesn't rotate relative to the stub axle.
The inner ring (the "cone") will slowly rotate on the spindle (known as "precessing", I believe) due to the action of the rollers rotating around it - it's a loose-ish fit on the shaft. If the washer is not tanged, it may well turn the nut if the split pin fails, either tightening it and destroying the bearing, or loosening it so the hub falls off. Make sure it cannot rotate.
Fjemog
1993 Plus 8
DaveW Offline OP
Post Photobucket rework................
And this one is a lot of work!!!!!!
Today I made a start on Mr Bumble's kingpins. First here's all the stuff on the bench.
IMG_5352 by David Wellings, on Flickr
I used some thick leather, doubled over as a buffer and the spinners came off much easier than the old earless spinners.
IMG_5355 by David Wellings, on Flickr
Here's my lifting beam under the cross tube and held by axle stands.
IMG_5354 by David Wellings, on Flickr
This next photo is quite important. The Caparo calipers don't use split pins, they have dumb bell like retainers which can be drifted out either way, but are held in place by "traditional" spring clips. I managed to damage one of the spring clips when removing, but have some new MGB clips in stock. However, although they look the same, the MGB items are very slightly narrower,so not really suitable as this would allow the pins to move slightly sideways. They would do as a short term fix. I rang BHM, but they don't carry the clips in stock, and have not supplied any. They don't come with new pads by the way. So I rang Rutters, but got the same response. So I've contacted Caparo direct, but am not hopeful as these parts are pence in value even though they are safety critical. I'm presently looking into an alternative source so will let you know what turns up.
The other important thing to note is that the pads have a lip on the outside edge caused by the pads slightly overlapping the outer edge of the disc. I've filed the lip away, but it will recur as the pad and disc don't exactly align!
These pads are exactly the same as on my Roadster which has the earlier Lockheed calipers.
IMG_5356 by David Wellings, on Flickr
I hung the caliper out of the way on a cable tie, after checking that none of the pistons were sticking.
Note that the flexihose is armoured, but also has a clear plastic cover. The plastic cover has been worn through in one place, which looks like it may have rubbed on the tyre or rim. So check yours...... This has not damaged the armoured braiding. When I fitted the brake reaction bars, I added a rubber hose buffer because the hose does touch the reaction bars. Note also that the caliper has two bleed screws.
IMG_5357 by David Wellings, on Flickr
Here's the split pin, just emerging at "two thirty" - o'clock. Needle nosed pliers are essential. The nut was finger tight, which is usual.
IMG_5364 by David Wellings, on Flickr
Here's the bare stub. The nut visible at 9 o'clock is the sensor I've spoken about before. A cable runs from the back of this, into the loom at a multi plug under the wing.
Note the end of the rack. The boot is only held on by a cable tie, so it's very easy to pop the boot off and check the state of the lubrication. Pack a bit of grease in the end if it's dry. If you put it on 'right lock', the rack will take the grease inside when you straighten up.
IMG_5365 by David Wellings, on Flickr
The S shape cable (below) is the sensor cable, which is threaded into the backplate and secured by the nut in the earlier photo.
IMG_5367 by David Wellings, on Flickr
This is the back of the disc (with fresh paint). Note the evenly spaced bolts and nuts. I believe these are to trigger the sensor, and I wonder if there will be this many on the other side.
IMG_5368 by David Wellings, on Flickr
And here we are with track rod end off, lower reaction bar removed, and lowering rods fitted ready. I've also cracked the top lube bolt, and bottom kingpin nut. Note that this stub axle is very sticky on turning and is grabbing the main spring, even though it has MMC steering bearings. When I get the stub off I will post pictures of the MMC bearing next to the Mulfab bearing.
IMG_5366 by David Wellings, on Flickr
I've been cleaning up as I've gone along, but be in no doubt that this job is incredibly messy. Grease everywhere......
Anyway, after a leisurely day, time for a break.
DaveW Offline OP
The next photo shows the difference between the MGB and Morgan retaining springs. I've had a response from Caparo, so will let you know the details as soon as I know more.
IMG_5369 by David Wellings, on Flickr
So - using the wind down method... this is how it ends up with tension off the main spring.
IMG_5371 by David Wellings, on Flickr
IMG_5370 by David Wellings, on Flickr
Then once you've removed the bottom plate, it lifts out.......
IMG_5372 by David Wellings, on Flickr
Here's a comparison between my original blue Roadster springs (marked "Plus 8"), and the Plus 4 springs - shorter to accommodate MMC steering bearings.
IMG_5376 by David Wellings, on Flickr
And interestingly, here are the rebound springs - the longer thinner ones are Roadster (05), and the shorter thicker springs are Plus 4. The coils are compressed at one end.
IMG_5377 by David Wellings, on Flickr
Next a comparison between the Mulfab bearings, which I will use to replace the original MMC bearings, and the MMC bearing which I've removed. MMC bearing on the left. The race is smaller than the mulfab race, and the MMC cover is rubber. As removed there was significant stiction in this bearing, which is why the steering was not as light as the Roadster, already modified with Mulfab bearings. The Mulfab cover is metal, and it turns much easier.
IMG_5373 by David Wellings, on Flickr
IMG_5374 by David Wellings, on Flickr
IMG_5375 by David Wellings, on Flickr
More to follow.............
DaveW Offline OP
Here's the top of the kingpin. As you would expect, it's as new, at 1" 'exactly'.
IMG_5378 by David Wellings, on Flickr
Here's the bottom. Admittedly not as bad as I expected:
IMG_5379 by David Wellings, on Flickr
But with a noticeable zig zag wear pattern with significant troughs:
IMG_5380 by David Wellings, on Flickr
There's also a witness mark where the bearing has been rubbing on the stub axle:
IMG_5382 by David Wellings, on Flickr
Now it gets interesting. Extracting the first bush is a test unless you use a press to push them both out the same way. This time I thought I'd try sawing down the length, so made up a special hacksaw from two strips of aluminium with a limited depth. This worked well enough, but that first bush still put up a fight.
IMG_5351 by David Wellings, on Flickr
For the second bush I used Mulfab's tool, and it came out easily........
IMG_5385 by David Wellings, on Flickr
And so to fitting the new bushes..................
DaveW Offline OP
For this I use threaded rod and bits & pieces collected over the years, plus suitably sized sockets to keep it all lined up.
Today the bushes went in easily................This is the lower bush with a socket over the top to help it align.
IMG_5389 by David Wellings, on Flickr
Here it is nearly home. The bush hanging out is an MGB anti roll bar bush which is a perfect size for centralising the threaded rod.
IMG_5391 by David Wellings, on Flickr
IMG_5390 by David Wellings, on Flickr
And here's the upper bush going in:
IMG_5392 by David Wellings, on Flickr
Reaming was straighforward. This photo shows the end of the pilot. It's only just long enough, and I've modified the end to provide a bit better fit in the hole. I suppose that techically it would be better done vertically!
IMG_5394 by David Wellings, on Flickr
And here's the business end. It's an adjustable reamer so I go in on a loose fit first, then progressively go larger, testing the fit after each pass - going in from each end.
I also use cutting lube and the reamer makes easy work of it with just light pressure to make it progress.
IMG_5393 by David Wellings, on Flickr
Until suddenly the pin fits! How tight is a bit subjective, but this is reasonably tight - it takes a bit of effort to pull it back out by rotation.
Note that it should fall through under its own weight or hold with some grease added.
IMG_5396 by David Wellings, on Flickr
Then it's important to clean up inside - I sluiced it with plenty of WD40:
First pass:
IMG_5397 by David Wellings, on Flickr
Second pass:
IMG_5398 by David Wellings, on Flickr
And then a bit more cleaning out followed.
Before degreasing, etch priming and painting. It's been a busy day, but it all went well.
IMG_5400 by David Wellings, on Flickr
IMG_5399 by David Wellings, on Flickr
No more spare time now until the weekend.
DaveW Offline OP
I'll repeat this from the other thread - Brake Component Part Numbers: A bit more information now:
Caparo spring & pin part number: HCK215
Morgan "genuine parts" number for spring clips MBS 0675 (Thanks Richard)
Now here's the best bit. Spring clips are available from Rimmer Bros:
QP2740 is 1 spring clip - Rover SD1 - 2 piston caliper. �1.60 each (incl VAT) and you need four.
Or STC8574P, which is Retaining kit, rear brake pads (aftermarket). Includes 4 clips and 4 split pins (you don't need the split pins). �3.90 incl VAT
So the set is cheaper than buying four clips seperately.
The special retaining pins are Caparo only so it looks like that will be a factory order unless you replace with bolts.
IMG_5409 by David Wellings, on Flickr
DaveW Offline OP
Yesterday and today I continued - first assembling the offside and the moving on to the nearside. I've decided to replace the pads with Greenstuff, which I'm happy with on the Roadster.
So - first I greased up the Mulfab bearing. It slots over the top and is a perfect fit.
IMG_5402 by David Wellings, on Flickr
Next the dust cover and bump stop was assembled and slotted over the top of the spring. I used the dust covers from the Roadster - I replaced them with new ones when I did the kingpins, then cleaned & repainted the old ones for the next job. The bump stop is a simple length of rubber hose which is a tight fit in the top of the dust cover.
IMG_5403 by David Wellings, on Flickr
Next I sprayed rust inhibiting wax into the cross tubes:
IMG_5404 by David Wellings, on Flickr
Note here the flimsier looking lower mount which was modified to accommodate the adjustable camber plates.
IMG_5405 by David Wellings, on Flickr
I also dribble a small amount of oil into the track rod end.
At this point it's coming on nicely and is ready for the disc. All nuts and bolts are checked twice. It's very easy when you are familiar with a job to forget something important!
IMG_5406 by David Wellings, on Flickr
And here we are back together apart from the pads........
IMG_5408 by David Wellings, on Flickr
DaveW Offline OP
There are different ways of pulling the stub axle into position. Using a long top bolt is a very good way, but I've settled on my two threaded rod method. It doesn't need spring compressors and the only tricky part is locating the lower nut on the kingpin - because I prefer to get the top lube bolt started early. The only thing to watch is when the top of the stub meets the dust cover on the way up. It may need a bit of persuasion to slot inside, but on this occasion it went in easily.
So today I started on the nearside:
First those pesky pad retaining clips......I found a suitable sized drift, but because the pads had pushed out slightly the pins were stiff to get out.
IMG_5410 by David Wellings, on Flickr
Here you can see the lips over the edge of the disc:
IMG_5411 by David Wellings, on Flickr
IMG_5413 by David Wellings, on Flickr
I thought I could get away with retracting the pads without taking some fluid out of the M/Cyl.
But Bumble peed on the floor! Or rather on the rubber mat........
IMG_5415 by David Wellings, on Flickr
Ready for lowering:
IMG_5416 by David Wellings, on Flickr
Here's the disc and you can see that it doesn't have the extra bolts on this side because there is no sensor on this side.
IMG_5417 by David Wellings, on Flickr
The kingpin was worse on this side than the other:
IMG_5418 by David Wellings, on Flickr
IMG_5419 by David Wellings, on Flickr
Again, the first bush was a challenge to get out, even though I hacksawed four slots in it this time, but not quite far enough!
But the Mulfab tool made short work of the second bush.
IMG_5420 by David Wellings, on Flickr
Then the new bushes went in easily. First the lower:
IMG_5422 by David Wellings, on Flickr
Then the upper:
IMG_5423 by David Wellings, on Flickr
This photo shows how the lower valance and tray seals off the front of the car from road dirt:
IMG_5421 by David Wellings, on Flickr
And finally, I painted the stub axle, ready for reaming tomorrow.
IMG_5424 by David Wellings, on Flickr
DaveW Offline OP
Well, the first observation is that the new pads when fully located still overhang the outer edge. The inner edge is bang up agaist the inner edge of the disc, so skimming a bit off each angled corner of the backplate, to 'edge it' down won't really work, although I did consider it.
I've had Greenstuff discs & pads on the Roadster for six years, they were fitted when I got it, and have been no trouble. Maybe I don't brake hard enough.
Anyway back to the story:
Here's a closer photo of the reamer. The silver tube on the right is the pilot with a sliding adjustable collar, which to be honest is not much use with Morgan stubs due to the length, but the pilot is essential to keep it straight. As the cutting blades adjust right to left they ride up a taper so cut a larger diameter hole, They are retained at each end by a taper threaded collar. Black on the left, silver on the right.
IMG_5427 by David Wellings, on Flickr
This show the model number - there are loads to chose from.
IMG_5426 by David Wellings, on Flickr
Reamer adjusted, job done, and cleaned out - I'm getting faster each time I do this.
IMG_5425 by David Wellings, on Flickr
Here's the nearside on the way up. I slot a screwdriver in the base just in case the rebound spring makes a bid for freedom, but it seems quite stable and once it gets inside the lower tube bracket it can't go far.
IMG_5428 by David Wellings, on Flickr
Almost back together:
IMG_5432 by David Wellings, on Flickr
Pads and lube - it's just like Coppaslip.
IMG_5433 by David Wellings, on Flickr
Not enough angle to see the overhang...........just visible as a pink band.
IMG_5435 by David Wellings, on Flickr
So all I have to do now is make up a set of deluxe gaiters as I fitted to the Roadster after the kingpin job, oh and then do a full service. Good job I'm part time retired, and that MrsW is tolerant.
And finally a double two fingers to Photobucket for causing all this re-posting.
clap clap thumbs
DaveW Offline OP
Here are the better pictures of the calipers & pads:
This one shows that the inside edge is right up against the wear ridge.
IMG_5438 by David Wellings, on Flickr
And this is the outer edge. It doesn't fit well......
Next time I'm in there I will chamfer the edges a bit.
IMG_5439 by David Wellings, on Flickr
