10 members (AlyMatt, DaveW, Luddite, lez, Biggle, sid, Jeff D, Laurens, PaulJ, Grumpy2), 140 guests, and 23 robots.
+8Rich 99
John V6 57
Topics49,910
Posts838,136
#461593 15/07/17 04:34 PM
SBM Offline OP
On a Trad chassis, where is the visible VIN stamped..? I understood it to be stamped into the passenger side cross member, visible from inside the car. But mine ain't..
Drivers side crossmember on the horizontal panel unless they forgot.
On my 1993 +4 the chassis number is on the driver side cross member behind the seat but I had to sand the paint away to make it visible.
Dirk
1993 Morgan +4 (Connaught Green)
2009 Mini Cooper D
2024 Mercedes GLC
1994 Ford Motorhome
SBM Offline OP
So far it's a bit elusive..
It's not on either of the chassis cross members ahead of the seats & those shiny covers do the trick of hiding the grey galvanising but are a pain to get off after a few years..!
Still hunting..
Black Rat
Black Rat
Still hunting..
Steve are you talking about the VIN number if so is it not under the bonnet on a plate by the fuse box
Keith
2013 narrow bodied + 4 Ruby.
SBM Offline OP
It is indeed, Keith. The trouble is, I have to offer a rubbing of the stamping to a nice lady at DVLA..
I presume that in the absence of a stamp it could be fixed at the factory using the stamp-on-a-cross-member jig.
Steve. It should be on the rear crossmember under/behind the driver's not the front one that's usually gets covered in carpet or posh shiny covers.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
JCK Offline
Hi,
https://www.dropbox.com/s/uiwb2izl7t3ci74/IMG_20170709_132309.jpg?dl=0
I exposed mine last weekend. The previous owner had scraped the paint off to reveal it. It is on the top of the cross member in the bottom right.This is a left hand drive car.
1959 Plus 4
JCK
1960 Plus 4 Roadster
Hello again Steve! I seem to remember that on later cars it is on the front crossmember. That's why there's no carpet on the crossmember. It was moved so that Police etc. could easily check the chassis no. Keep us informed!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
