1 members (Pyewacket),
226
38
Topics49,911
Posts838,147
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
On a Trad chassis, where is the visible VIN stamped..? I understood it to be stamped into the passenger side cross member, visible from inside the car. But mine ain't..
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Drivers side crossmember on the horizontal panel unless they forgot.
Posts: 537 Likes: 28
Posts: 537 Likes: 28 |
On my 1993 +4 the chassis number is on the driver side cross member behind the seat but I had to sand the paint away to make it visible.
Dirk
1993 Morgan +4 (Connaught Green) 2009 Mini Cooper D 2024 Mercedes GLC 1994 Ford Motorhome
So far it's a bit elusive..
It's not on either of the chassis cross members ahead of the seats & those shiny covers do the trick of hiding the grey galvanising but are a pain to get off after a few years..!
Still hunting..
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Still hunting.. Steve are you talking about the VIN number if so is it not under the bonnet on a plate by the fuse box
It is indeed, Keith. The trouble is, I have to offer a rubbing of the stamping to a nice lady at DVLA..
I presume that in the absence of a stamp it could be fixed at the factory using the stamp-on-a-cross-member jig.
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Steve. It should be on the rear crossmember under/behind the driver's not the front one that's usually gets covered in carpet or posh shiny covers.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 321 |
Hi, https://www.dropbox.com/s/uiwb2izl7t3ci74/IMG_20170709_132309.jpg?dl=0I exposed mine last weekend. The previous owner had scraped the paint off to reveal it. It is on the top of the cross member in the bottom right.This is a left hand drive car. 1959 Plus 4
JCK 1960 Plus 4 Roadster
Hello again Steve! I seem to remember that on later cars it is on the front crossmember. That's why there's no carpet on the crossmember. It was moved so that Police etc. could easily check the chassis no. Keep us informed!
