1 members (sewin),
159
40
Topics49,838
Posts837,294
Auto-Seal
I was at the Silverstone Classic weekend and watched a demonstration of this product, very impressive, but has anyone got any experience of it?
Worthers+8
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
I have used a similar product, Puncturesafe, in the tyres on my M3W. It has been in them for 4 years, 13000 miles, with no detrimental effects, no punctures either ! The only down side was when replacing the front tyres, because of wear, I had used it in the tubes and the wheels could not be balanced so I had to have new tubes as well as tyres.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Red Leader
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
After a rear puncture on last year's 'Goggles & Gauntlets' which resulted in a humiliating trip home from Dorset to Leicestershire courtesy of the AA, I too decided to investigate these products. After some research, I plumped for OKO because they offer different formulations for different tyre sizes rather than a 'one size fits all' approach. Also, they are used by the UK armed forces and emergency services which is a good enough endorsement for me!
I used the green 'motorcycle' product on the fronts and the blue 'On Road 4x4' product on the rear. I haven't noticed any difference to the way the car drives - just a warm, fuzzy, peace of mind feeling while driving!
Andy
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Given Tarka has no spare and I really wouldn't like to have it hauled on to a truck I wondered if OKO might work, but they do not recommend for 40 profile tyres or lower and also not with V, W, Y or Z rated tyres. So that rules out Tarka.
My next thought is that when I change the tyres I'll fit Dunlop Run Flat tyres and fit a tyre pressure monitoring system.
Posts: 595 |
Well that rules my Aero +8 out then which is a great pity as we are looking to do a trip to Lake Como next year after the LMC and was looking for peace of mind. On a separate note I had the opportunity to have a good look at a Triumph Thruxton whilst at the Silverstone Classic weekend and fell in love with it but SWMBO said NO! Well you cannot win them all mores the pity.
Worthers +8
Worthers +8 I'm going to fit the TPS monitoring system from Tyre Pal, This LINK gives all the details, for around £100 it seems reasonable. The dash mounted unit is Size 84 (L) * 66 (W) * 23 (H)mm and 6,6 cm will just fit on the dash. It will, at least warn me of any deflation. Then when I have to change the tyres I'll fit the latest run flat tyres from Dunlop. As to the Thruxton 1200 R I didn't ask... I suffered somewhat.. But the boss has accepted that it was something I had to do. I think she has got over of it.
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
I prefer a pressure gauge! My parent's car has a built in monitoring system which flashes up occasional warnings for no good reason as does the one in my Fiesta. Also, when I fitted winter tyres on rims without pressure senders in them it did flash up a warning but took about three weeks and a few hundred miles to notice and flash up a warning
Posts: 625 |
Have had run flats on a Merc (and weirdly seen them fitted to a Lotus Elise which is insane as Elise tyre are specifically designed for them with thin supple sidewalks to match the suspension) , the side walls are hard as nails and they are noisy. I would not have them again by choice Peter.
Cheers John 2011 4/4 - "Elrond" 2007 Elfin C3 Clubman - “Gimli”
Posts: 41 |
Be careful of Autoseal. If your car is with an internal Tyre Pressure Monitoring System you may find that Autoseal may block the sensor. Check with the car maker!
Eddie Hayden
