9 members (TBM, Sir Percival, Mark+4, Ian Wegg, Luddite, Burgundymog, Neville1, RichardV6, TheRabbit),
264
74
Topics49,867
Posts837,624
Posts: 491 Likes: 6
Posts: 491 Likes: 6 |
Good to read that John.
Are the new wheels on Nero yet?
If they are would love to see the pics. Errr.....no. Not quite a simple swap of wheels. The centre of the Minilites are slightly thicker and therefore the studs not quite long enough for safety. Williams are fitting longer studs for me and spacers as the wheel offset is different. Another couple of weeks hopefully. Jays, when i fitted minilites to my widebodied 4/4 i just used longer nuts, they were chrome dome nuts but with twice the length of thread
2015 +4 and 2000 4\4 1981 Lambretta GP225 1960 Lambretta LI 125
Posts: 14,009 |
Hugo...it's the lack of length of stud that's the issue...longer nuts will make no difference as there are so few exposed threads available! And that's even without fitting the spacers.
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Yes. Nice little drive out to Woburn as Caron needed to pick something up in the Woburn China Shop. There's a staggered crossroad in the centre of Woburn that leads to a lot of confusion, anger and the bibbing of horns with very little way given by any car. Not so for a Morgan as I found out today. As I turned out of where I had parked into the mayhem, politeness and civility took hold and I was waved through by all sides. Nice! The joys of driving a Morgan!
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
If i remember correcly the original minilites used long sleeved nuts that went through a larger hole in the wheel its self, with a large fitted washer to butt up aginst the wheel.
Posts: 28,902 Likes: 352
Posts: 28,902 Likes: 352 |
You certainly wouldn't get that in a Porker  Definitely one of the joys of Morganning.
Posts: 14,009 |
If i remember correcly the original minilites used long sleeved nuts that went through a larger hole in the wheel its self, with a large fitted washer to butt up aginst the wheel. More conventional now. There's sleeved steel inserts which probably are akin to the sleeved nut and washer....and conventional blind nuts.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Greased the front end and cleaned out the K&N air filter so I did a little run around the Chilterns.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Nothing overly exciting, went to work and back, accompanied by the 3.0 thrum is a nice way to commute!
Went to Brixworth near Northampton for work to see a pump supplier.
Whilst overcast with the old light drizzle the A&B roads were great fun.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Whilst overcast with the old light drizzle the A&B roads were great fun. Should've dropped in for a brew, John. Only two miles away..
