9 members (johntinline, jim109b, AndyrIch, BLUE+4, Jeffpee, Paul F, RibbleAdventures, Ruut Bianchi, teknome),
195
40
Glitch
Topics48,331
Posts812,878
Members9,203
Posts: 25 |
During my trip to RFTH last week I noticed a new noise coming from the backend of my M3W. It sounded like something rubbing and it happened each time the rear wheel went round. This resulted in the car sounding slightly like a steamtrain as I was going along, emiting a like of sh..sh..sh..sh..sh noise. The noise has lessened over the last couple of days but this evening I took the boot liner out and found that a chunk of the edge of rear sprocket has sheared off. My guess is that this has somehow been the source of the noise, possibly somehow rubbing against the belt.  Should I be particularly concerned by this? Jim
2017 M3W, Sport Green/Tan
Posts: 1,338 |
I would remove it, I don't think it's a problem. I just saw my new steel sprocket for the first time.
Posts: 1,363 Likes: 11
Posts: 1,363 Likes: 11 |
Remove it. It will damage the belt as it is. You probably don't need the flange. I have the SuperMax sprocket and there is no provision for a flange and I have found it unnecessary.
Posts: 46 |
Always good to shed weight! I also removed the aluminium sheets attached to the lower seat back, going up underneath the upper seat back. Made no difference, except making life easier and car lighter Anyone tried to remove the circlips on the bonnet dzus fasteners so that they can be kept in ones pocket while removal/installation of the bonnet? What else can be binned? Another wheel perhaps?!
Posts: 655 Likes: 1
WW11 MOG Talk Morgan Regular
Posts: 655 Likes: 1 |
Mind did that. Remove the full aluminium lip and the belt will happily overhang the edge of the rear sprocket. It's not a problem
Posts: 1,673 Likes: 25
Posts: 1,673 Likes: 25 |
If you do decide you want to replace the aluminium ring, I have a spare one that I could send you for the price of the postage. It became 'spare' when I was supermaxed. PM me if interested.
Andy
Posts: 3,658 Likes: 48
Posts: 3,658 Likes: 48 |
They come off with a pair of pliers but are almost impossible to get back on I replaced mine with circlips which are just loose on the shaft of the duez clip. I can check the size when I'm back from Grindelwald The Garage 56 spring kit works well and eases removal and refitting
Red Leader
Posts: 7,916 Likes: 216
Posts: 7,916 Likes: 216 |
These worked for me when fitting G56 kit
Posts: 25 |
Thanks for the information. I'm going to take the flange off to avoid damage to the belt and hopefully this will also cure the noise. I won't bother replacing it for now. At least, not unless the belt starts working its way off the sprocket.
Also +1 for the Garage 56 bonnet spring kit
Jim
Posts: 2,539 |
