Morgan Aero 8
1 members (JohnMat), 267 guests, and 103 robots.
+8Rich 76
Topics49,869
Posts837,666
Moggo
Page 1 of 4 1 2 3 4
#470107 01/09/17 05:23 PM
Michael Offline OP
I think my Aero battery is slowly giving up so I want to replace it with a heavier duty one, the current one is 58AH and 450A.
Can anyone recommend a good quality battery that will fit but of a higher capacity the the current one?
Michael
Michael
Aero 8 S4
Michael #470133 01/09/17 07:44 PM
Why not replace it like for like?
Martin (Deano)
deano #470147 01/09/17 08:19 PM
Michael Offline OP
I am hoping to get a battery that will last longer when stood idle
Michael
Aero 8 S4
Michael #470175 01/09/17 11:30 PM
Battery ideally should be matched to the alternator.
Turning off the current vampyre in the MORGAN odd electrics will make the battery last longer when idle.
Mark - No Longer driving
Michael #470190 02/09/17 06:32 AM
Hi Michael, I had the same problem with the battery only lasting a couple of years but after isolating the car - which I believe Mark is referring to -if I know I wont be using it for at least another week the battery has now lasted over 5 years. I don't know if you are familiar with the isolator and I am struggling to upload a photo !!
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Michael #470195 02/09/17 07:28 AM
You don't have a switch inside the bonnet on the engine to switch off the electrics as in the 4.8 Aero engine ?
Michael #470201 02/09/17 08:43 AM
I always leave mine plugged into a battery conditioner unless I'm going to be driving it the next day
Simon
Series 1 Aero 8
Michael #470206 02/09/17 09:18 AM
Michael Offline OP
I do have a red isolator switch on my S4 in the engine bay but I don't want to use that as I then have to reset windows when powered back on, I keep all my cars on a ctek but my battery drains quite quickly if not used and I am planing trips where we won't have access to charging and in the autumn stood in hotel car parks may test the battery.
My thinking is not the overall life of the battery but how long it takes to drain it and so a heavier duty battery seems one possible solution.
Michael
Michael
Aero 8 S4
Michael #470214 02/09/17 10:22 AM
Formerly known as Aldermog
The battery in Tarka is from mid 2013, according to the sticker. It will last for about 2 weeks without the trickle charger, but if the radio is left on the battery goes flat over night.
How do I know this, yes, I found out the hard way.....
As has been said, a larger battery, if beyond the capacity of the alternator, won't help.
A trickle charger is the cheapest solution, I feel.
Michael #470225 02/09/17 11:47 AM
U
TM Photographer of 2008
U
For back-up whilst travelling get one of these or similar.
Ken
Page 1 of 4 1 2 3 4
