12 members (MartinB60, Grumpy2, Paulxj, BobtheTrain, ScotiaSteve, DickJ, Moggo, Vansrv6, Alan Patterson, DaveW, RichardV6, Luddite),
372
53
Topics49,860
Posts837,493
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
A couple of months ago there was a mention of bevel box gear lapping done in Australia. This interested me greatly as my bevel box is both noisy and a screamer, at most speeds. I made contact with Three Point Classics in Melbourne. They advised they had done two bevel boxes, one 100% and second say 60% improvement. Encouraging i thought. This was done by getting gears lapped.
So, out with the box. I had done this a couple times before as my box has been "fiddled" with by diff and gear companies. Neither made much difference, possibly worse.
The whole box is quite damn heavy, so being a cheapskate, i decided to just send the gears which was ok by TPC. The breaking down of the box required assistance from our mechanic friend to remove the sprocket (this is very tight and resisted my attempts with a gear puller) and to undo the pinion and sprocket nuts. Next issue was the pinion bearing which i left on the shaft to send away.
Courier cost to Oz was 100 NZD. Weight approx 9 kg Lapping was done and gears returned about a week later Pinion bearing was removed for the lapping. New one required
Next, Superfinishing. The ring gear and pinion gear done. Really shiny finish, mirrorlike. This should reduce friction to very low levels and assist in running cooler and quiter, hopefully.
Right, moving closer to the final straight. Time to rebuild This mean repetitive closing and checking contact patterns. Due to design of box its impossible measure backlash properly so its down to feel. First job was to get new pinion bearing and press onto shaft (got help on this). Made sure to put old shim on shaft before bearing! Second, tighten pinion sub-assembly to check preset load. With the fixed shims I managed to get 5-6 inch lbs. Turning gear felt "right" First assembly highlighted that it wasnt possible to see the marks on the pinion or ring gears to make sure they lined up. So undo and use Sharpie pen to make the pinion tooth and the two ring teeth which need to mesh Paint ring gear with poster paint ( i didnt have marking blue!), reassemble and turn gear forward and backward a couple of times. I didnt like the contact position so spoke to the Lapping company direct. Sent pictures. Was advised to move pinion in towards ring by 5 thou. Didnt want to ruin pinion bearing by removing it to place shimm behind. Was advised it was simpler to pop out the bearing cup and put shim behind the cup. Did this with a bit of judicious drifting Repeated paint, close, turn, open and inspect. Looked like an even contact over most of the teeth. Checked by sending pictures and got OK. Now, final reassemble. Only tricky bit being the sprocket. Plenty of oil on splines, wooden block and judicious hammering slowly did the job. Make sure it gies right to the collar on the shaft. Why? Well if you think its a good idea to leave a bit further out for better belt alignment, dont do it! There is so little room between flange screw heads and swinging arm they hit!
Final act, fill with 300 ml gear oil as its easier on the bench. I decided to use a lesser EP 90 for first fill and to run for say 50km to allow settling in etc If all is well will change to 100% Lucas gear oil stabiliser
Whilst keen to try a run, have spent a bit of time aligning drive belt and retensioning. Besides its very wet st present.
With the car ready to run just had to wait for a break in the weather.
So the climax!
A very short run was very promising. Belt stayed on sprocket too! So , cajole the wife to be a witness and set off for the motorway to see if we still scream.
To cut to the chase
No screaming! Wife happy as refused to ride at speed due to screaming (cars not hers!)
I can only pick a noise at approx 60kph which is quite muted. Similar to loudness of urban cooling fan
Okay, its not so warm here at present at 16 oC and we only did 20 km BUT there is a vast improvement! Yes ! Time will tell
Apologies for the long ramble but its worth the explanation!
Some pix in next post
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Sounds promising.Might do mine in the winter months!
Posts: 398 Likes: 1
Pictures ring gear match teeth marking  pinion gear, before, with bearing  ring gear first pattern. too high on tooth  superfinished shiny pinion  lapped pinion gear  lapped ring gear  pinion collar and shim  pinion subassembly  second contact pattern is okay
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Thanks for all the info and photos P964. Quite a lot of work to get the optimum Bevel Box set up and possibly minimum noise. "Bwitched" did a similar job, without the lapping, back in April 2015 and had good results. You can see why Quaife probably are not taking the time to set the pre-load and gear contact up to close tolerances as it isn't a quick job or easy task. You may be lucky and get one that is close to the best settings, or not.
Another winter job maybe? Very interested in what your longer term and well heat soaked long run observations are like. My bevel box screamed it's way to and from Grindelwald last week, it gets no worse or better and I would like a cure other than better ear plugs.
Posts: 6,538 |
Great work on the gear lapping and thanks very much too for the comprehensive pics.
This seems to be the way to go with BBs.
But help me out ...why oh why have Quaife not done this .
Other than cannot be bothered!
Neil
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Other than cannot be bothered! More like can't afford to I would think. Lapping each bevel box in and setting it up as carefully as P964 has done would probably double the price of the box, and I suspect MMC specified a much lower price point than Quaife were able to meet with that level of detail finishing.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Interesting stuff and great result.
Richard 1976 4/4 4 Seater
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
Very interesting and hopefully a good result.
Martin (Deano)
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
I agree the time needed on each one would see Quaife going backwards
99 plus 8 indigo
Posts: 1,562 |
I agree the time needed on each one would see Quaife going backwards When it is properly proved as a solution , perhaps Morgan should consider offering it as a cost option ? Like mudguards, windshields, bonnet fasteners etc. Pretty ironic you would have to pay extra to get it right but that seems to be the Morgan way unfortunately.
