6 members (JMcL, SEG, BobtheTrain, Zach, MartO, CooperMan), 233 guests, and 22 robots.
+8Rich 96
John V6 51
Topics49,902
Posts838,049
#47374 15/07/10 05:09 PM
2 years after Richard Thorne fitted electronic power steering for plus 8, has been an excellent decision until drive back from LMC on Monday. During heavy rain and generous ingress of water into cockpit (as hood was down) the power steering started to cut in and out repeatedly. This made turning the car at lower speeds interesting. Not so bad at high speed as p steering not active much above 30 mph. Car is about to be returned to RTCC for diagnosis and hopefully treatment.
LMC was very good, my 1st morgan event
David R
Green 2001 Plus 8
That sounds like water in the electrics. A neoprene shield might help...... innocent
Good idea, will post the RTCC diagnosis (and hopefully solution) once they have reviewed.
Until now, it has been a good thing and I was glad to have had it fitted. I guess water and electrics don't go well together
David R
Green 2001 Plus 8
Or you could spray with damp start!
Green & Grown Up
Green & Grown Up
Putting the Hood up (or even a Garden Umbrella) might be a better idea. doh idea hide
Not so easy at 70 mph on the motorway
David R
Green 2001 Plus 8
Richard Thorne have now sorted this at no cost. The problem, as predicted was water ingress via the engine bay onto the electronics around the steering column within the drivers' footwell.
All that was required was extra sealant around additional holes they had drilled plus around the usual suspects that come as "factory standard". have driven in the rain since and all is well.
David R
Green 2001 Plus 8
