Posts837,277
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
Hi James, I will check the measurement tomorrow ... in the end they replaced the 'boxes' under the running boards just after the cats and then straight through. I love the noise, really been a great improvement from the original. Ian thanks Ian  When you say "in the end they replaced the boxes' under the running boards" - was this with straight through pipe to the rear or did they fabricate some new style boxes which are less restrictive? James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 11,520 Likes: 312
Posts: 11,520 Likes: 312 |
There is a company in Southampton which is well know for custom fabricating exhausts Peter. I was looking at taking the ML63 down to have some of the muffle removed prior to a DMS re-map for a laugh.
The issue is that change of back pressure on a large scale can adjust the map and tune etc.
Posts: 263 |
No boxes at the rear at all, one issue is that there is a need for a few angles in the pipe on the way back, but seems ok ... and the £500 that it cost for the job, cans, pipe and tailpipes not too bad! I will try and find way to let your hear the noise ... I assume too big a file for the usual means but I will see if we can use Dropbox and give whoever wants a link. I am away from home until this evening but sounds like a job for tomorrrow afternoon 🤓
Aero-Ian
Aero 8 Series 1 Defender 90 BMW 330d M Touring
Posts: 336 |
There is a cold start vid on You tube of mine if that helps at all? [video:youtube] https://www.youtube.com/watch?v=3J0yzvuroMw[/video]
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
There is a company in Wilton, Torque Technique: www.torquetechnique.co.uk/who can probably advise. Tarka has a single oval silencer under each running board, nothing at the back. The 1 into 2 finishers are a bit restrictive at the end. I am wondering about a slim glass pack silencer and new end pipes.
Posts: 263 |
 n   James ... the diameter of the tips is 9.5 cm The silencer under the running board sits a little lower than the original but is still higher than the lowest parts of the underside and is not noticeable from standing
Aero-Ian
Posts: 263 |
Apologies that the cleaning of the underside is not up to standard and the tips have not recently been polished 🤓
Aero-Ian
Posts: 263 |
Aero-Ian
- looks good Ian;thanks for posting  James
Posts: 4,646 Likes: 123
Posts: 4,646 Likes: 123 |
Only been for an evening swim at the local leisure centre, but stepping out of the car to open the garage door - these things do look fantastic in the dark with their lights on; especially with that big old moon shining down on it.
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
