10 members (Lordofthewings, sprinty, davewhite, PeteMalvern, Uerikonplus8, Paul F, How, Black Adder, RichardV6, Dada),
345
33
Topics48,346
Posts813,060
Posts: 2,539 |
I know someone posted the service checklist, but darned if i can find it! Can anyone help?
Posts: 1,670 |
It's in the Handbook if that helps
Posts: 2,539 |
It does but there was another form a 8 & a half by 11 full sheet checklist (A4)
Posts: 2,539 |
Posts: 1,670 |
Nice one Draggin, never seen that before.
Posts: 989 |
It should also have "check oil tank rubber seal for security and condition" In case its breaking up and about to starve the V twin of its oil supply. Yes they do break up and do just that. Well my 2015 did - several days after its first service at a dealer who should know better!
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
Posts: 1,544 |
My oil tank seal crumbled! removed oil tank washed out (and lines to engine) new filter new oil, make new seal from oil resistant rubber and larger washer,all good so far
Posts: 2,539 |
Maybe I will end up having the dealer do the first service after all. And then do all the subsequent ones myself.
Posts: 7,924 Likes: 217
Posts: 7,924 Likes: 217 |
Maybe I will end up having the dealer do the first service after all. And then do all the subsequent ones myself. In the UK you loose the warranty if the handbook is not dealer stamped with service intervals. Is it different in the USA?
Posts: 1,490 |
Maybe I will end up having the dealer do the first service after all. And then do all the subsequent ones myself. In the UK you loose the warranty if the handbook is not dealer stamped with service intervals. Is it different in the USA? Not in the US and hard to believe it’s that way anywhere. If you have the receipt from the work being done that should suffice. In the US you don’t even have to have oil changes done by the dealer during warranty, just proof it was done at all.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
