Topics49,844
Posts837,364
Posts: 1 |
Gents, My Plus 8, 3.9 had the vacuum advance tube disconnected by the previous owner. I have now found out why it was disconnected after finding that the diaphragm assembly was loose and causing erratic and sticking advance and retard settings.
I would now like to refit the tube to give me better cold starting and smoother running.
Can anyone help me out with a photo of their distributor alignment with the shot being taken from above the belt pulley?
May thanks Mikey
Jaguar Signal Red, 3.9 Plus 8
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
I will see if I can do that later today Mikey.
Posts: 853 |
Mike, if you want a pic now, pm me your email address and I can send
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
Posts: 26 |
Gents, Could you include me on the communication here - my 3.9 is running a little lumpy...(occasionally cuts out)
Appreciated Kevin
Posts: 853 |
Update, I sent Mike a pic of my distributor set up but it is not the same as his. Mike, you could put your pic on here and ask again. Someone will recognise a similar setup and send pic. I have had a couple of issues with my car. Very Occasional pinking and even more occasional cutting out. Nothing to worry about but if anyone has any comments I would be grateful.
PS Mikey, I omitted to welcome you to the forum, I am sure you will find out all you need in due course.
Posts: 1,943 |
Here I go discussing a subject I know little about. BUT! There is an Amplifier on or near the Dizzy. If on the Dizzy it gets hot and fails. Some move the amplifier to a cooler place. BTW: as I do not have Fuel Injection I replaced My Dizzy with a DELCO Dizzy. The DELCO is an old fashioned Points Dizzy used on the Buick 215. Predecessor of the Rover 3.5 & 3.9.
Button
