10 members (Montegue, Biggle, Image, MATTMOG, Pipmac, mph, RubyMog95, Zach, Graham, G4FUJ, TBM), 309 guests, and 86 robots.
Sagging Hood
Topics49,859
Posts837,477
#476355 09/10/17 08:12 PM
I want to replace ignition switch/steering lock on my 1999 4/4 is the switch a Land Rover Part as my local dealer wants mega bucks for Morgan part
It may be Landrover or possibly MGB. See if you can find a part number on it.
Ray Offline
Try Terry Foxen at GEE, think he stocks them.
Do you have an immobiliser? If so its probably Land Rover. Whats wrong with original one?
Have a look at this discussion. Talk Morgan » Forums » Morgan Sports Cars » Maintenance & Servicing » Replacing the Ignition Switch
Mine was a land rover on my 88 4/4
Graeme: 2011 +4
About £37 -off ebay or £100 off uncle melvin.
bugger to do
I did mine this year!
I'll sort details of switch and pm you
http://www.talkmorgan.com/ubbthreads.php/topics/346944/Re:_ignition_switch_failure#Post346944
See here
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
Depends which switch, My 1972 4/4 has a Neimann which has the actual switch independent of the key barrel. This means that you can replace the switch assembly whilst still retaining the original key.
The switch assembly is readily found at jumbles, its from an MGB, BL Mini Mk3 and various Vauxhall/Bedfords
Arwyn
Key gets intermittently jammed I have lubricated it to no avail
What did you lube it with? Not oil I hope? Locks need graphite powder.
Mark - No Longer driving
You may had to drill out the bolts as the head sheers off at the right torque for "security" reasons. If this is the case you may wish to replace with normal bolts.
