7 members (+8Rich, DaveW, GrumpyPa, Ritchie B, Gordon D, Themorganeer, Stevo666),
236
74
Topics49,861
Posts837,529
Posts: 3 |
I want to replace ignition switch/steering lock on my 1999 4/4 is the switch a Land Rover Part as my local dealer wants mega bucks for Morgan part
Posts: 22,360 Likes: 353
Posts: 22,360 Likes: 353 |
It may be Landrover or possibly MGB. See if you can find a part number on it.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Try Terry Foxen at GEE, think he stocks them.
Posts: 6 |
Do you have an immobiliser? If so its probably Land Rover. Whats wrong with original one?
Posts: 1,711 Likes: 1
Posts: 1,711 Likes: 1 |
Have a look at this discussion. Talk Morgan » Forums » Morgan Sports Cars » Maintenance & Servicing » Replacing the Ignition Switch
Mine was a land rover on my 88 4/4
Graeme: 2011 +4
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
About £37 -off ebay or £100 off uncle melvin. bugger to do I did mine this year! I'll sort details of switch and pm you http://www.talkmorgan.com/ubbthreads.php/topics/346944/Re:_ignition_switch_failure#Post346944 See here http://www.talkmorgan.com/ubbthreads.php/topics/346944/Re:_ignition_switch_failure#Post346944
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Depends which switch, My 1972 4/4 has a Neimann which has the actual switch independent of the key barrel. This means that you can replace the switch assembly whilst still retaining the original key.
The switch assembly is readily found at jumbles, its from an MGB, BL Mini Mk3 and various Vauxhall/Bedfords
Arwyn
Posts: 3 |
Key gets intermittently jammed I have lubricated it to no avail
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
What did you lube it with? Not oil I hope? Locks need graphite powder.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
You may had to drill out the bolts as the head sheers off at the right torque for "security" reasons. If this is the case you may wish to replace with normal bolts.
Richard 1976 4/4 4 Seater
