Morgan Aero 8
3 members (tezzer, MartinB60, Rjh), 291 guests, and 88 robots.
Topics49,848
Posts837,408
DazMog, The Impaler, tlchzj79
Page 3 of 8 1 2 3 4 5 6 7 8
To the best of my knowledge.....
S1
Crank Driven Honda/Rover Pump (many retro fitted with later BMW electrohydraulic pump kit)
Morgan/Jack Knight Steering Rack
S1.5 (facelift )
BMW Electrohydraulic pump
S2 & S3
BMW Electrohydraulic Pump
BMW Steering Rack
S4 & S5
BMW engine driven Pump
BMW Steering Rack
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Formerly known as Aldermog
Many, many thanks Simon, useful information.
I suspected that much of the S4 was BMW as the power steering fluid reservoir is exactly the same as the one on the 330SC my son had!
The S1 reservoir is BMW as well.... banghead
Simon@ SiFab.co.uk
Simon @ Sifab.co.uk
Prity sure my 2012 plus 8 has a electric pump under the passenger wing as it had to be replaced under warranty.
Martin (Deano)
It might well do
As with most things Morgan there's no hard and fast changeover dates
And in all honesty my major experience is with the early cars and when we raced the Aero in British Gt's and Britcar, I threw away or heavily modified much of the OE equipment to make the car reliable (and faster)
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Smile, it confuses them
I have a vague recollection that my Series 2 had a failure not long into my ownership and the dealer replaced it with a Mini electric pump to drive the existing hydraulics and rack. This was mounted in the inner wing ?
Simon, what about the GTN's? S1.5? S2?
Aero 8 GTN. #10
The GTN's are the last of the S1's. although 1 was built with a wide body that was subsequently adopted as the S2 body
As far as I know, all the GTN's were fitted with the original Honda/Rover pump. Your's certainly is/still is.
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Thanks for clarifying Simon, having never having had a detailed look on the steering I could only go on what RT said when I spoke to them previously.. the fact that it stays hydraulic is a big bonus.
So to clarify is the mod on the Series 1 using a Mini pump the same as the BMW pump being used on the Series 2 onwards?
Thanks,
Nick
Aero 8 GTN #11
Kind of...on S2/3
Different rack, different plumbing, different wiring
But yes, just the same..... crazy2
S4 onwards is (I believe) using the engine driven pump not electro-hydraulic
The MINI pump is no longer available new (although I do have a limited supply), there are also a couple of generations of the MINI pump and you need the right one, also a couple of the plumbing connections are unique
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
