7 members (Ritchie B, Bitsobrits, Tony Quinn, IcePack, Rog G, DazMog, Image), 294 guests, and 104 robots.
+8Rich 77
Topics49,868
Posts837,642
Moggo
#477425 17/10/17 10:38 AM
Whilst installing a K&N filter on my 2016 4/4 Saturday, I noticed that the live cable to the fan switch has worn through to the bare wire, it had been rubbing against a bracket next to the air filter box.
I have managed to wrap insulation tape round it as a temporary measure. I believe this cable cannot be replaced as the fan switch Is a sealed unit? should this be covered and replaced under the manufactures warranty? or further still should it be a recall as it could be dangerous ?
My local mechanic said he can replace the cable and heat shield it.
I have emailed the dealer on the weekend, but still waiting a reply......
Any advice on this would be appreciated
Craig Jezz
Craig Jezz #477426 17/10/17 10:53 AM
Well spotted Craig.
I'd be inclined to put a Butt Connector in there and tie wrap the cable so it doesn't chafe again.
https://www.maplin.co.uk/p/maplin-insulated-crimp-terminal-butt-splice-blue-jh80b
There is a tool for these but if you are careful you can crimp them with pliers if you are unfamiliar with them do a trial first maybe. I would think the Blue one is probably the size to chose from the pack.
If you have a local agricultural supplies shop most stock these or any auto supplies store.
Craig Jezz #477453 17/10/17 02:20 PM
Thanks Richard, looks like I will have to give this ago.....
Craig Jezz
Craig Jezz #477506 17/10/17 07:35 PM
Hi,
On my 4/4 Sport Morgan 2009 I got rid of the air filter box and installed an open air filter system K&N nr 57-0686 (Ford Focus II 1.6 L VCT, 113 BHP 09/2004-2010).
Easy installation, simple filter maintenance and no problems of chafing cables; also nice sound improvement.
D'Herde Bart
Craig Jezz #477521 17/10/17 09:20 PM
If you think its a potential warrenty/recall issue then take it back to the supplying dealer. People on here will always have an opinion but only the dealer is in a position to give a truly informed opinion.
Craig Jezz #477533 18/10/17 05:05 AM
As Andy has already advised; start with you dealer and ask them to raise it as a warranty claim with MMC.
Martin (Deano)
Craig Jezz #477535 18/10/17 06:06 AM
If it were mine I'd solder in a new piece of wire and heat shrink wrap it. I'd also put something along the sharp edge, a bit of split tube etc. Connectors can fail and let water in, the less the better.
If your local guy has already said he can do it why not let him? Probably cheaper than your fuel and easier than faffing about with the dealer.
Craig Jezz #477539 18/10/17 07:08 AM
I agree with Steve. If you are modifying your car yourself by putting non-standard air filters on then I wouldn't be too expectant of getting much dealer support under the warranty.
It's a simple problem with a simple fix. Get your local man to sort it out.
SteveT #477597 18/10/17 01:14 PM
Agree Steve, that's my plan
Thanks again for all the advice on TM
Craig Jezz
Hamwich #477601 18/10/17 01:32 PM
If you zoom into the K&N sticker on the image, it says "The use of a K&N air filter will not void your vehicle's warranty"
Craig Jezz
