9 members (deano, Julian BB, Alan Patterson, Image, Roady, Clipper, RichardV6, Hamwich, Pittsartist),
279
74
Topics49,859
Posts837,511
Posts: 1,415 |
To the best of my knowledge.....
S1 Crank Driven Honda/Rover Pump (many retro fitted with later BMW electrohydraulic pump kit) Morgan/Jack Knight Steering Rack
S1.5 (facelift ) BMW Electrohydraulic pump Morgan/Jack Knight Steering Rack
S2 & S3 BMW Electrohydraulic Pump BMW Steering Rack
S4 & S5 BMW engine driven Pump BMW Steering Rack
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Many, many thanks Simon, useful information.
I suspected that much of the S4 was BMW as the power steering fluid reservoir is exactly the same as the one on the 330SC my son had!
Posts: 1,415 |
I suspected that much of the S4 was BMW as the power steering fluid reservoir is exactly the same as the one on the 330SC my son had! The S1 reservoir is BMW as well.... Simon@ SiFab.co.uk
Simon @ Sifab.co.uk
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
Prity sure my 2012 plus 8 has a electric pump under the passenger wing as it had to be replaced under warranty.
Martin (Deano)
Posts: 1,415 |
Prity sure my 2012 plus 8 has a electric pump under the passenger wing as it had to be replaced under warranty. It might well do As with most things Morgan there's no hard and fast changeover dates And in all honesty my major experience is with the early cars and when we raced the Aero in British Gt's and Britcar, I threw away or heavily modified much of the OE equipment to make the car reliable (and faster) Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Posts: 11,528 Likes: 312
Posts: 11,528 Likes: 312 |
I have a vague recollection that my Series 2 had a failure not long into my ownership and the dealer replaced it with a Mini electric pump to drive the existing hydraulics and rack. This was mounted in the inner wing ?
Posts: 1,646 Likes: 1
Posts: 1,646 Likes: 1 |
Simon, what about the GTN's? S1.5? S2?
Aero 8 GTN. #10
Posts: 1,415 |
Simon, what about the GTN's? S1.5? S2? The GTN's are the last of the S1's. although 1 was built with a wide body that was subsequently adopted as the S2 body As far as I know, all the GTN's were fitted with the original Honda/Rover pump. Your's certainly is/still is. Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
Thanks for clarifying Simon, having never having had a detailed look on the steering I could only go on what RT said when I spoke to them previously.. the fact that it stays hydraulic is a big bonus.
So to clarify is the mod on the Series 1 using a Mini pump the same as the BMW pump being used on the Series 2 onwards?
Thanks, Nick
Aero 8 GTN #11
Posts: 1,415 |
Kind of...on S2/3 Different rack, different plumbing, different wiring But yes, just the same.....  S4 onwards is (I believe) using the engine driven pump not electro-hydraulic The MINI pump is no longer available new (although I do have a limited supply), there are also a couple of generations of the MINI pump and you need the right one, also a couple of the plumbing connections are unique Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
