Morgan Aero 8
2 members (mph, +8Rich), 367 guests, and 90 robots.
Topics49,848
Posts837,402
DazMog, The Impaler, tlchzj79
#478737 25/10/17 08:40 AM
V
V70LER Offline OP
V
Hi All, opened up the fuse area today expecting to see a nice serial port staring back at me... how wrong I was. Where the hell is it? I'm guessing it's in there somewhere as it's marked on the top of the box as being in there!
I've checked under the steering column and cabin wiring and no luck?
V70LER #478740 25/10/17 08:58 AM
- it's a trip back under the steering column for you I'm afraid eek
If you look under the steering column and to the right on the dashboard surround (the black plastic bit) you should see a small, flip down flap.It is fairly far back and easy to miss.
Open this up and you have the OBD port..... thumbs
Hope this helps, James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
V
V70LER Offline OP
V
Thanks James! I knew the fact it was marked on the fuse box would probably be a trap! haha
V70LER #478790 25/10/17 12:59 PM
V70LER,
I am interested to know what you are planning to do when you have found the OBD port. I believe the ECU was programmed by Morgan and not left standard by BMW.
V
V70LER Offline OP
V
Sure, I was just researching an engine light today - wonkey O2 sensor on the left bank.
The ECU is a Bosch ECU and then should be fully programable though but haven't researched it :-)
