3 members (SteveT, vincentvg, Strathaven), 188 guests, and 105 robots.
Topics49,848
Posts837,401
DazMog, The Impaler, tlchzj79
Page 2 of 8 1 2 3 4 5 6 7 8
I would consider myself an enthusiastic driver. While the Cokers did outlast the Blockleys I sensed no difference in grip. I think the main difference is that the formulation on the Blockleys may be old school while the formulation on the Coker line is very modern.
The 'rubber' just seems to hold up better.
My Avons lasted 7,000 miles and my 1st set of Blockleys 11,000.
They are a great improvement over the Avons and I've just had a second set fitted at MWS.
Red Leader drive
My Avons lasted 10000 miles
I must admit I was trying to wear mine out and did a few track days/events innocent
Red Leader drive
My first pair of Avons lasted about 3,000 miles. I then learned to up the pressure from the recommended 22lbs to 27. It helped but not by much.
For any interested in keeping Avons in the future please remember that this particular tire is for the rear/side car of a motorcycle. It was not designed for the stresses encountered by a steering wheel holding up so much weight!
Its bias rating resembles that of a soft noodle...
If I remember correctly I got almost 5000 miles from the original Avons and have had from 5000 to 7000 out of each pair of the Blockleys. The current pair must be on about 6000 at the moment with a fair bit of tread left.
I currently have Coker Excelsior Comp H tires and am very happy with them.
I have a question on the Avon tires.
I take it these are 19", but they are truly motorcycle tires, not a side car tire? Or are they as someone said, rear motorcycle tires?
Yes, I think the side wall strength would be a bit different than a car type or side car type tire. But I remember seeing pictures of MMC racing a M3W with 18" fronts and Avons.
Do you know what the load rating is for the Avons and speed rating? Not many tires have a load range high enough for the weight of the M3W.
Just curious, thanks.
Dan
Hi Dan, i think the tyres you are thinking about are Avon Am26 Roadrider tyres. They have a wide profile for racing etc and come with 149mph rating. They are 130/80/18`s.
Sorry if i am wrong.
John.
Ps, they have a load rating of 66, which equals 300kg and a speed rating of V which is 149mph.
John.
John, thanks for the info on the 18" tires.
But what are you guys running that are 19" Avons?
Dan
