0 members (), 414 guests, and 25 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
Page 5 of 5 1 2 3 4 5
madmax #480568 03/11/17 09:08 PM
miles of smiles
miles of smiles
I think you’ve made a good move and Morgan must have done something right or we wouldn’t both be attracted to the brand. TheARP4 is the one I would swop for too, but I don’t want to be without any cars I already have, so I’ll just have to save up and get them all!
Post up some shots please, especially the red chassis, I’d buy one just for that alone love
madmax #480688 04/11/17 11:04 AM
8000 miles in and still loving the ARP4. Personally I would have preferred an engine with more torque lower down in the power band but as previously reported I've now learnt how the Cosworth engine needs to be driven - and it's great fun if you enjoy the gear changes and the high revs. Unlike Eddie I actually love the pops and bangs of the rev overhang but that of course is a personal preference, and you just can't beat the styling of that dashboard. I'm also a fan of the LED lights and the gloss wheels.
I've just posted on another thread that the handbrake issue was resolved by switching to softer brake pads - the original MMC 'fix' having failed to do the trick. Krazy Horse sorted this one.
Had to replace the 'sender' when the engine oil light lit up, and a new fuel tank was needed when the original split at the seams causing petrol to splash out when going round a bend with a full tank - took a couple of thousand miles to work that one out (my thanks to BHM), as I'd been told that the smell was probably due to me not driving the car fast enough and not therefore burning off the fumes!
It's a super car but it seems to me that with Morgan it's simply a matter of matching the right model to the whims and wishes of the particular Morgan lover. There's one there for all of us but it's not always easy to get it right first time - especially (as with the release of limited editions such as the ARP4), if there's no opportunity for a test drive prior to purchase.
Bob
2016 ARP4 Porsche Prosecco
2018 Plus 8 Bentley Satin Grey
madmax #480708 04/11/17 12:19 PM
The ARP dashboard is so good that it should have been made available on the Plus 4 as an option. I would have had one.
DaveW #480720 04/11/17 01:10 PM
+1 and the Babydoll one.
DaveW #480727 04/11/17 01:30 PM
But how could MMC release a high powered car with an expensive engine and no oil pressure gauge?
Easy enough to put right of course, like most of the other 'faults' and ommisions on the car. I am planning to take out the clock and put the oil pressure gauge in that position. The big problem is to find a matching bezel. Does anyone know who makes the existing 52mm dials in the +4?
Whilst at it, I plan on having a changeover switch so that I can put an oil temperature sender in the dry sump pan, and use the existing water temperature gauge to display both.
A couple of nice little winter jobs to keep me from being under my wifes feet!
PaulJ #480788 04/11/17 06:20 PM
Formerly known as Aldermog
Didn't Smiths once do a a gauge that showed oil and water temperature, 2 needles on one face?
Amusingly the C43 has 3, yes Three, temperature gauges.....the standard water one, a pseudo analogue one in the instrument cluster, plus digital ones for oil temperature and gearbox oil temperature. It takes far, far longer for the gearbox oil temperature to reach "normal" than the engine oil and the water.
The "book" advises not using the Sport plus mode until the gearbox is properly warm.
madmax #480794 04/11/17 06:39 PM
"The "book" advises not using the Sport plus mode until the gearbox is properly warm."
I have that problem too Peter, except in my case as it's fully manual it's me that has to warm up for those quicker changes!
Peter J #480821 04/11/17 08:27 PM
Thanks Peter blush I should have read my handbook more closely...
Does your C43 have an F1 style "lift and save" mode on trailing/zero throttle? My 45 does - deactivated until all fluids including gearbox oil hit operating temperature. Makes a noticeable (+/-5mpg) difference to consumption - until I figured out the link to gearbox temp I thought the car had an intermittent fault hide
Stuart
