Topics49,858
Posts837,463
Posts: 1,943 |
As I often take long trips I am sensitive to wheel bearing failure. My Mentor has often told Me, if a long trip is planned, grease the front wheel bearings. It is good insurance if nothing else. Greasing includes cleaning them first, inspecting and then good clean grease. I used to use a fixture to insure the grease got into the bearing. Now I just use My fingers and need the grease into the bearing.
Button
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Job done. The bearings were as in the link to gomog earlier posted. I bought from Wych bearings as per Arwyn’s recommendation. Straight forward replacement process with no hitches. The failure was in the outer bearing where some damage/erosion was visible on the outer race. Couldn’t see any reason for it as everything looked good. Ah well, one of those things.
Posts: 1,036 |
Good news Phil! Wheel bearings rarely fail but when they do, they let you know by the noise.
True. I noticed mine on pre MOT check. Raised the car front to check everything and noticed the faint noise on spinning the wheel. No play felt. I must have caught it very early. Car passed MOT today. Advisory for one tyre nearing the limit. All 4 are due replacement anyway so no worry there. I am tempted to have the alloys refurbished at the same time as the coating is detariorating on the inner surfaces. Now....what colour? Currently silver. Tempted with black.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Good to hear both re the bearing and also the MOT.
Richard 1976 4/4 4 Seater
Posts: 310 Likes: 9
Posts: 310 Likes: 9 |
Sospan, I was waiting in anticipation for the part numbers of the bearings and especially the oil seal.  Regards,
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Posts: 1,103 Likes: 17
Posts: 1,103 Likes: 17 |
Need to do the front wheel bearings on my car. I found the ones on the Wynch’s website. Does anyone have the part number for the grease seal it is a 1996 +4? Many thanks Will
