8 members (Rex_tulips, +8Rich, B&C Morgan, BobtheTrain, nick w, howard, RichardV6, Grumpy2),
326
Topics48,362
Posts813,329
Members9,215
Posts: 26,759 Likes: 424
Posts: 26,759 Likes: 424 |
I have the MDE 4000 in my 4/4 2005. The car has the posibility for 2 speed fan. (Easy fix) I´m working with a PCB-les car. At the moment I only use the PCB for engine immobiliser, engin and battery warning light. I think this 3 light are from the ECU. Are there anybody that have en ECU wire diagram? Picture of my dashboard: https://flic.kr/p/21sb8EwAnd my wire diagram: https://flic.kr/p/21sbj47 Oylo, on Sunday we had the dash out with the 20A fuse for the fuse box & the 20A fuse or the dash unit out. I rebuilt the dash & the car restarted without those fuses in. It seems to me the immobiliser just a feed to the lights off the PCB if the engine starts. John
Posts: 1,639 Likes: 20
Posts: 1,639 Likes: 20 |
The PATS LED is connected to the pcb but is wired directly back to a -5v output from the ECU (pin.42). The board contains no immobiliser functionality.
Roger 2011 Plus 4
So could we infer the MIL & battery light are also via the ECU?
Yes I believe so but not directly… I am not an electronic engineer but it looks to me like they (and the temp gauge) unfortunately use secondary circuitry to interpret a data stream from the Visteon ECU. I’m guessing that is why Peter has managed to throw away his board and MFU as the Omex ECU may well handle these outputs differently  The other important immobiliser item, the transponder electronics module on the streeling column is driven by tx/rx signals directly from the ECU, so no board worries.
Roger 2011 Plus 4
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
The Omex installation doesn't have much to do with the instruments, there is a connection which replaces the MIL light, other than that the instruments, where applicable, are still driven by the original ECU. The Omex ECU only handles engine management.
Posts: 3,547 Likes: 4
Posts: 3,547 Likes: 4 |
I reckon the main instruments are driven by the caerbont box?
That intercepts the ecu outputs I think?
The side lights fuse also feeds the dash lighting which would possibly tie up with Johns symptoms?
The Omex installation doesn't have much to do with the instruments, there is a connection which replaces the MIL light, other than that the instruments, where applicable, are still driven by the original ECU. The Omex ECU only handles engine management. The temp gauge is the curious gauge as its driven by the ECU (i think). If there is only one resistive temperature sensor on the engine (that cannot be shared) and that now goes to an input on the Omex, the original ECU no longer knows the engine temp. So what drives your temp gauge? Have you added a second sender or is there a gauge output from the Omex?
Roger 2011 Plus 4
Well spotted. The Omex kit includes a temperature sensor that is used exclusively by the Omex ECU. It is place in the coolant tube which passes under the intake manifold, though older installations involved fitting one to the motor. This is now avoided as it would mean removing a part, drilling and tapping a hole for the sensor and then replacing the part. Fitting it in the tube is much easier   There is also an intake air temperature sensor and an optional air pressure (for altitude) sensor that is normally not required/used in the UK. In effect the original coolant temperature sensor is now used only to drive the temperature gauge via the original ECU.
Aha!
Roger 2011 Plus 4
My Module numbering on the black plastic covering is
MDE 4003 v1.13
Dash Module V6 . 4/4
236206 0710
That would infer it was different to the Plus 4 I guess?
