3 members (B&C Morgan, BLUE+4, John Winn), 265 guests, and 57 robots.
+8Rich 82
Topics49,859
Posts837,500
Jonny72
#482874 14/11/17 07:06 PM
dmh Offline OP
Will need to choose new tyres soon for our 2011 3L Roadster.
The original Factory fit was Avon - steering is fine but we do get "poor behaviour at the back end!"
Any thoughts on the new set to choose please?
Cheers
David H
I have Dunlop SP sport for good grip in the wet & low noise.
David, do you look for 205 60 oder 205 65?
dmh Offline OP
Hello Heinz
Just checked - and the tyre size is 205/55 R16.
What do you think please?
Cheers
David H
I went for Avon ZV7s. They seem very good.
David H,
I have the following tyre on an old 1973 Porsche 911 in of course another size. It performes very well and has a reasonable price tag.
https://www.dunlop.eu/en_gb/consumer/tires/sport_bluresponse/205-55-16-91-V-3188649819256.html
I did not know you are searching for a 16 diameter tyre which means you might use stainless spoke wheels? This tyre is very good on a Porsche which means, if the predecessor of this tyre was a Porsche „N“ recommendation (they quit to test all the descendants of any brand) it should be also a very good performance tyre on a Roadster. The cars als quite similar regarding the weight, the 1973 Porsche is about 1040 Kg and therefore a little bit heavier but not too much.
Please check if my example shows the right load index for the Roadster, my search was quick...You could give it a try.
Those are what I took for my 2006 Roadster as I wanted wet grip
David
For a 16 inch rim and 55 profile look no further than the Toyo Proxes T1R , fabulous tyres in wet and dry, and available quite reasonably from many outlets.
https://www.camskill.co.uk/m62b0s291p133599/Toyo_Tyres_Car_Toyo_T1R_Proxes_Toyo_T1_R_-_205_55_R16_91W_TL_Fuel_Eff_%3A_F_Wet_Grip%3A_C_NoiseClass%3A_2_Noise%3A_70dB
Andy G
1999 +8 , Indigo Blue.
+1
I got them from Blackcircles.com at a very good price.
dmh Offline OP
Thank you all - am going for one of these - will see how prices work out.
Cheers
David H
