7 members (MATTMOG, Sir Percival, gomog, Hamwich, SteveT, Chris99, uvk33n), 214 guests, and 32 robots.
+8Rich 99
John V6 57
Topics49,909
Posts838,132
#484323 21/11/17 05:32 PM
Jads Offline OP
Sorry if this has been covered in the past.
I have just started replacing the very worn CVH valve stem oil seals (head still on), and wondered whether it is worth fitting new valve springs ? If recommended, has anyone got a set they don't need ?
The engine has obviously been well looked after. There is no appreciable wear on the camshaft lobes, still giving a lift of just under 0.24 of an inch, and the compression is up to spec and equal across the cylinders, so I am tempted to leave well alone.
Thank you in advance, John.
Jads #484331 21/11/17 05:51 PM
How many miles has it done?
My thought would be to change the springs given that you are taking the old ones off.
There is a school of thought which says valve springs go weak over time rather than through fatigue but I've never really subscribed to it
Try Burton Power for a new set of springs
Arwyn
Jads #484351 21/11/17 06:39 PM
Jads Offline OP
It has done 100,000 miles, drives really nicely, and the engine has never been touched, except for regular servicing.
Given what I understand to be the already very high loads on a CVH valve gear, I feel reluctant to use non Ford springs in case they have a higher spring rate ? ie Burton's springs are described as heavy duty ?
John.
Jads #484446 22/11/17 01:03 AM
Jads , Burtons are THE Ford engine experts, real quality stuff and recommended.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Jads, I have used Burton springs on two CVH heads I have rebuilt and not had an issue
Graeme: 2011 +4
Jads #484456 22/11/17 07:04 AM
100k?, well due for a change I'd reckon!
Heavy duty doesn't necessarily mean increased spring poundage.
Arwyn
Jads #484527 22/11/17 02:44 PM
Jads Offline OP
Thank's everyone, new springs ordered from Burton, and less than 1/2 the price of Ford.
John.
