Topics49,908
Posts838,124
Posts: 122 |
Sorry if this has been covered in the past. I have just started replacing the very worn CVH valve stem oil seals (head still on), and wondered whether it is worth fitting new valve springs ? If recommended, has anyone got a set they don't need ? The engine has obviously been well looked after. There is no appreciable wear on the camshaft lobes, still giving a lift of just under 0.24 of an inch, and the compression is up to spec and equal across the cylinders, so I am tempted to leave well alone. Thank you in advance, John.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
How many miles has it done?
My thought would be to change the springs given that you are taking the old ones off.
There is a school of thought which says valve springs go weak over time rather than through fatigue but I've never really subscribed to it
Try Burton Power for a new set of springs
Arwyn
Posts: 122 |
It has done 100,000 miles, drives really nicely, and the engine has never been touched, except for regular servicing. Given what I understand to be the already very high loads on a CVH valve gear, I feel reluctant to use non Ford springs in case they have a higher spring rate ? ie Burton's springs are described as heavy duty ?
John.
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Jads , Burtons are THE Ford engine experts, real quality stuff and recommended.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,711 Likes: 1
Posts: 1,711 Likes: 1 |
Jads, I have used Burton springs on two CVH heads I have rebuilt and not had an issue
Graeme: 2011 +4
100k?, well due for a change I'd reckon!
Heavy duty doesn't necessarily mean increased spring poundage.
Arwyn
Posts: 122 |
Thank's everyone, new springs ordered from Burton, and less than 1/2 the price of Ford.
John.
