4 members (RichardV6, bmgermany, Nickplus4, Alistair), 329 guests, and 45 robots.
+8Rich 91
Topics49,841
Posts837,318
Page 8 of 10 1 2 6 7 8 9 10
thierry242 #480237 02/11/17 03:11 PM
And two English cars have been ' destroyed' , does that mean they won't be re- built ?
Andyhirst #485153 25/11/17 11:26 AM
API Offline
Originally Posted By Andyhirst
Can you add mine
SA94420K2F0004226
Body 100404
Prosecco Gloss
Thanks
Andy
Une 23eme ARP4
+4 SS 61 #4884/101
Aeromax #95/100
ARP4 #F4200/50
ARP4 #G4026/50
http://www.Collection-voitures.com
thierry242 #485290 25/11/17 11:16 PM
Hi Daniel
about time I gave you my info too:
body no. 100314
chassis: SA94420H2F0004186
Prosecco, cuba/ivory leather, power steering, heated seats
Bob
2016 ARP4 Porsche Prosecco
2018 Plus 8 Bentley Satin Grey
API Offline
Originally Posted By hARPpy chappie
Hi Daniel
body no. 100314
+4 SS 61 #4884/101
Aeromax #95/100
ARP4 #F4200/50
ARP4 #G4026/50
thierry242 #486828 03/12/17 11:08 AM
Well, that's around half the production run, only another 25 - 26 to find then. You have to be patient in this game don't you?
A thought has just occurred to me. There was supposed to be a run of only 50 made, but does this include the well used proseco development car? Maybe 51 were made in total?
thierry242 #486878 03/12/17 05:31 PM
Could be even more than 51 Paul - I heard the MMC computer took a few more orders than it should have done before someone realised and popped a stop on the order book!
Bob
Oh no! Bang goes our exclusivity then, retained values down the pan and one on every street corner......
thierry242 #490770 26/12/17 02:36 PM
Happy Christmas and New Year to all fellow ARP4 owners around the world.
Following on from a nice chat with Stefan at Run for the Hills, I have replaced the plastic mirrors on Morag with the carbon fibre version of the same design from Demon Tweeks which look fabulous. Thanks to him for that inspiration.
From the outset I've had the Moto Lita wooden wheel on the car which I transferred from my previous Mog 'Molly". It has great sentimental value but the brown wood didn't quite sit right to my eye in the cockpit of the ARP4. So I have just received from Morgan Park in Germany a gorgeous looking black wooden wheel. I saw this on their stand at Run for the Hills (and I then sat on the same table as them at the Gala Dinner).
I will post some pictures when I have had the steering wheel fitted.
A couple of questions for fellow owners.
Mirrors. Horizontal adjustment of the mirrors is dealt with by simply loosening the bolt on the top of the mirror. To adjust the vertical angle of the mirror arm, do you have to unscrew the whole arm from the car to loosen the adjustment which is at the back of the base of the arm?
Secondly, night driving. Has anyone come up with a neat and sympathetic way to illuminate the switchgear at night?
Many thanks and kind regards
Ian
AR P4 Kingfisher Blue - Morag
Formerly 2007 Plus 4 - Molly
Worcestershire
Biffo Smith #490885 27/12/17 05:33 PM
Ian
Thanks Ian and a I hope you and yours had a good Christmas and will have a great New Year, same to fellow ARP4 owners and all TM members.
With regard to steering wheels, my car has the excellent electric power assistance, so I have fitted a 12" (300mm) Momo leather wheel which gives perfect feel, and more importantly allows me to see the 7500rpm redline on the rev counter, as well as the red line change up light, normally covered by your left hand, RHD cars only of course. It still allows full view of the fuel and water temp. gauges as well as making getting in and out easier too. There are just so many advantages, I wouldn't go back to the original.
With mirrors, you shouldn't need to take them off to adjust them once the friction screw in the base has been adjusted so that it holds the mirror in position, but you can still move it, with some effort. The problem is that the nearside mirror tends to unscrew itself and hang down. I would bet we have all suffered from this little glitch? The answer is to use some threadlock so that in normal use this doesn't happen. Whatever you do though, don't tighten the friction bolt up too much as it will just split the mirror base - don't ask me how I know......
With regard to the switches, the only one I need in a hurry is the spot lamp switch, which on a RHD car is on the bottom row and nearest to the wheel, so I have made an extension from a short length of copper tube and just put over the switch with some tape under it. The end is flattened and I can now find it easily with one finger, in the dark. The other switches don't get too much use, except the ignition and starter and as they are in the middle and only used when the car is stationary, are easy to find. My heated screen doesn't appear to work at all, so until it is fixed I don't need that switch, and the others seem to fall to hand when needed. Having said all that, I wouldn't have thought a small light under the dash roll would be too difficult to rig up. It could have a red low wattage bulb and would make the dash look quite sexy.
I am seriously thinking of removing the clock and fitting a Stack oil pressure gauge in the hole, as well as making the water temperature switchable for oil as well, I feel I need more info. on that expensive engine.
I've also fitted a large polished aluminium oddments storage tray on the top of the tunnel, not too pretty but very useful.
I'm still working on the radio, currently I've got a 'Pure' pocket receiver into which I plug the phono lead. It sort of works, but with no aerial socket, it loses the signal too easily once on the move. Has anyone found anything better, short of actually fitting a proper radio and aerial?
thierry242 #490888 27/12/17 05:48 PM
Hi Paul
Thank you very much for your helpful reply.
Yes I have suffered from the mirror flopping down which is partly why I have been loath to mess with adjusting them too much.
Like you, the only switch I really need to access in a hurry at night is the driving lights so I think I will try something like you have. I also like your ideas with the gauges.
Cheers
Ian
Worcestershire
