7 members (CBY, James B W, Luddite, Camelot, Bishmog, 42w203, mph), 467 guests, and 41 robots.
+8Rich 69
Adam12 69
John V6 52
9,215 Registered Users
Latest toy…
by Grumpy2 - 03/08/25 08:06 AM
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,376
Posts813,548
Members9,215
Same here in Belgium... I keep filling with 98 Octane, the 95 Octane is now "corrupted" with Ethanol.
Any UK M3W going through belgium => go 98 Oct!
Pure Gas
Not according to this!
Ok 16 mile round trip to nearest purges station.
Hardly convenient.
kirkusblog.com
1952 Ford 8N
After brimming with fuel I leave the cap open for a mile or 2 and never have a problem.
I found this out by accident one day as I forgot to snap the fuel cap down after filling
I assume that you don't fit the locking cap inside the fuel filler Dab? Any luck with fixing the problem Rolsmith? If it was just overfilling it should have cured itself by now, if it wasn't......?
It is hard for it to cure itself when it won’t start☹️. Since all diagnostic results pointed at the injector, I did what I should have done a few days ago. I swapped the injectors side to side and the the problem followed the injector. My dead cylinder now fires and my good cylinder is now dead. I ordered 2 replacement injectors and they should be here Monday. I ordered 2 because you just never know...
The pins on the bad injector ohm out the same as the the good injector,so I do not know what the failure mode is. I did flush out the “bad” injector with some wd40 before swapping sides and saw no debris of any kind. If there was dirt in the fuel, I don’t see how it gets past the filters. I would have thought both injectors would clog if dirty fuel was the case.
The car gradually ran worse and worse the last mile home so maybe whatever moving part is inside the injector was just slowly freezing up.
The winter weather here in Arizona (mid 80’s today) is far too nice to have a garage bound M3W, hope to be out and about on Monday!!
Possibly give it a squirt of ether Easystart engine starter or WD40 into the intake to get it running.
Strongly advise against using an ether based product to start an engine. It's like taking a sledge hammer to the pistons
No joy here in Mudville (baseball poem where the mighty Casey struck out). After exhausting my bag of trouble shooting tricks, I had the rig transported to Brighton Motorsports just across town. They no longer sell Morgan’s but still service them and Simon, the mechanic, is quite knowledgeable.
After determining that there was adequate fuel pressure, he found zero compression on the suspect cylinder. I should probably buy a compression gauge.
Tear down and diagnosis to follow.
JFP Offline
Hopefully, it's nothing worse than a broken valve spring.
Compression readings on these are weird due to the easy start cams. Mine only reads about 60 psi cold while cranking.
1959 4/4 - sold
1957 +4 - sold
2017 M3W - sold
