3 members (Image, Luddite, Nickplus4), 398 guests, and 19 robots.
+8Rich 92
Posts837,284
#24637 07/01/09 07:29 PM
DaveW Offline OP
Now then, sometime ago on Mogtalk we were chewing the fat about Roadster relays & relays in general. I managed to take this photo camera of my 05 Roadster installation, and Colin Jones5857 did the impossible ooo and came up with the functions.
So L to R it's:
Cooling Fan (High Speed)
Cooling Fan (Low Speed)
Ignition ECU
Fuel Pump
Start
The big one it turns out is wiper delay.
The relays must be fitted with a diode. They are behind the speedo & revcounter and the photo was taken with the drivers door wide open looking up above the steering cowl.
Why can we not have wiring diagrams from Morgan?
Because they don't use wiring diagram? smile
H3
H3
They're mostly available here.
1972 4/4 2 Seater
Many moons ago I recall one of my first motors an MG 1949 TC came with a handbook complete with wiring diagram plus a lubrication wall chart listing what oils, grease and lubrication intervals to apply to each part of the vehicle. So useful.
Graham
Octogenarian - (82)
1.8 4/4 Ivory
ToyoYarris
VolvoV70
I think the lubrication chart was probably supplied by Castrol. I had one for my MG Midget. Very useful and gave all the points that needed lubrication
Neil
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Formerly known as Aldermog
But not for recent Morgans....
My 2009 Roadster has all the electrical stuff in a nice aluminium box mounted next to the heater under the bonnet and above the driver's legs (on a UK car). All very simple and accessible. As far as I can see and confirmed by Jay's photos, there are only wires behind the dash.
Lucky lad - on my 2009 plus4 a lot of the electrics are up behind the dash and need a dash drop to get at unless you are a contortionist!!!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
There is one relay Peter behind the dash on the right hand side. Not sure what it is for.
I guess the only way to find out is to take it out and see what doesn't work! sherlock
My guess? The heated screen. But I'm probably wrong!
