6 members (Alistair, RichardV6, Jensen1960, +8Rich, ScotiaSteve, moggin), 217 guests, and 58 robots.
+8Rich 79
DaveW 51
Topics49,864
Posts837,580
Page 3 of 3 1 2 3
The Urban Cooling Kit isn't the most elegant of things but you shouldn't be so dismissive of it's benefits for the S&S engine in the M3W installation Phil. Excessive heat will kill your expensive engine and the buzz of the fan on a hot day in traffic is very reassuring. I have an oil pressure and temperature gauge and I can assure you that the cooling kit does work and does keep things just within reasonable limits.
It also helps duct cooling air to the back of the engine when on the move, as it was never designed to run with only one side into the airflow, unlike a Guzzi. It's not pretty but it is a help to keeping your engine happy.
Have to say I too get a lot of reassurance from hearing the fan cut in on my new M3W when stuck in traffic. My old 2013 one used to get super hot and I used to be quite worried leaving it when I parked it in case some gawker burned himself on it. I’ve noticed on the new one that the exhausts don’t seem to get
as hot either (my last car burned a very nice hole in my hockey stick bag when I accidentally leant it against one of the exhausts!).
ShaunD #494596 19/01/18 10:50 AM
The factory cooling kit is just too damn ugly for me, so I made one myself. Clearly not as efficient as the fully enclosed version, but 100% better looking in my view and I've not had skipfire since fitting it, so it must be doing some good. Manually switchable, so all very easy and no mucking about with ECU's required...
My DIY Fan Thread
I've got to say with the M3W having cooked on the London DGR a few years ago and it going into skipfire mode it was an awful experience plus difficult to get back underway. I dislike the ugly cowl of the fan and would gladly exchange for the love jugs set up I've seen or a discrete fan like R1NGA's any day. But unfortunately you do need a fan.
Sorry Dimitri, it is as I feared, your thread has been disrupted by my rambling on about the cooling pack. So - "back to you at the studio" as they say on TV.
No worries Phil, my custom cooling pack is almost ready - so I can jump into the debate smile
Finally been able to give the car a solid shake-down; everything standard 2013 - with the only additions the bolt-in brace, centra Drive with Phil’s inserts and bearing, and Phil’s bevelbox’ top bracket only (front and back brackets not needed for non-NVH cars), and new tires (Blockley front, Yokohama back). The belt has about 10 degrees slack.
First impressions......finally the car it always should have been. Take off in 1st gear with clutch control only is a breeze - no need for additional throttle input (previously, needed about 1800-2000 rpm in order not to stall). In dry conditions, wheel-spin in 1st, 2nd, and 3rd gear when going flat out. And the wheelspin is now controlled by the throttle, rather than the on-off-on pattern experienced previously (assumed to be as the slack shifts front to back through the drivetrain - and back).
Car can easily be driven between 1000 and 3000 rpm in lower gears, without a near total absence of clunking. It’s also possible to take off from stand-still in every gear all the way up to 5th gear.
In 4th and 5th gear, there is noticeable vibration (but nothing as compared to before) between 2600-3000 rpm, which feels more like a gearing mismatch between engine and gearbox. Dropping a gear appears the solution here, and easy to drive through.
One big difference, is that throughout, irrespective of revs or gear, there is a chassis vibration that can be felt backrest of the seat. It’s minor, and almost feels like a back massage.....I’ll call this a feature :-) not sure yet how annoying this will get on longer trips.
Overall I would say, success! And the car finally feels like a nimble little sports car. She definitely feels faster off the line, and I was going 100 miles an hour (on circuit) within the blink of an eye. What has become very obviou however, is how twitchy and unpredictable the front end is. Pushing harder, in combination with the Blockley’s appears to be the “culprit” here......now, this is without the steering kit, so next step is to install the modified Suplex (without the internal rebound spring!) and drop the ride-height down to how Malvern originally intended it.
To be continued.....
Page 3 of 3 1 2 3
