Topics49,844
Posts837,354
Posts: 8,663 Likes: 408
Posts: 8,663 Likes: 408 |
Is the purpose of this kit to get rid of bevel box whine or some of the other Driveline noises I think Phil's kit is to engineer better support for the BB where/when its needed, making for a mechanically superior installation. Reducing noise would be a gratefully accepted secondary benefit given the BB is no longer smashing against chassis and trim
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
If you don’t have the NVH bracket which thankfully I don’t, would the top bracket with the jacking screw on it’s own be of any benefit .
I don’t experience any clonking.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
I don’t experience any clonking. The original BB mountings were pretty solid so I doubt that the top bracket would buy you anything.
Andy
Posts: 655 Likes: 1
WW11 MOG Talk Morgan Regular
Posts: 655 Likes: 1 |
You’ll be able to judge fir yourself at Curborough!
Posts: 1,562 |
I have had three bevel boxes , and all three have had front oil seal problems. In removing the nodding donkey action at the front of the bevel box under hard acceleration and the stress this must put on the front bearing and associated parts like oil seals, i am hoping with Phil's kit fitted my repaired box will have a longer life than its predecessors. Anyone changed the bevel box oil seals?
Posts: 2,539 |
My cover over the driveshaft has the notches inside it too from the NVH Kit slapping it.
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Ooh yes! they all do that sir!!! as the saying goes!
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
I probably need to ping Phil about this but... I see there are now 2 options for this BB mounting kit upgrade (aka NVH kit fix)... fabricated steel mounts vs aluminium billet mounts. Presume the former are potential rust areas vs the latter being expensive? Anyone decided between the 2?
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
I opted for the billet kit, lighter and rust proof. It has arrived but I have not had a chance to install it yet. Very nicely made pieces.
