5 members (BobtheTrain, John Winn, Gordon D, IcePack, Elliot), 278 guests, and 39 robots.
+8Rich 92
Posts837,279
Bunny Offline OP
I'm in the middle of fitting one of Phil's kits to better locate the bevel box to the chassis. As I've removed the existing gubbins, I've found telltale signs that confirm that the NVH hardware has allowed significant movement of the bevel box.
This photo shows where part of the NVH hardware has been striking the chassis.
...and these marks are on the transmission tunnel cover:
A closeup showing a nice imprint of one of the hex mounting bolts:
I'm sure this explains the loud clonk when getting off the line (especially when carrying a passenger) and I can't wait to be rid of this unwelcome feature!
Of course, the irony is that my (early) chassis originally had the BB hard-mounted to the chassis but the previous owner had had it 'upgraded' to NVH spec! doh
Andy
Bunny Offline OP
Here is the BB mounting kit as received from Phil. Weight of all parts: 3.4kg (7.5 lbs)
And here is the old NVH hardware: 9kg (19.8 lbs)
Andy
Is it just a case of removing the old NVH parts and fitting Phil's kit or do you have to remove all the mounting hardware as well?
Bunny Offline OP
Hi John,
Yes, basically you remove the NVH kit and fit Phil's BB mounting brackets instead. It's quite a big strip-down involving removal of most of the interior trim but nothing too onerous for the home mechanic. For more details may I refer you to the installation instructions: Bleazey BB mounting kit
Andy
WW11 MOG
WW11 MOG
Great to see you’re getting your hands dirty Andy and it should help get the power down without fuss at Curborough πŸ˜€πŸŽπŸŽπŸŽπŸŽ
Bunny Offline OP
happy3
Andy
Can you fit to a 2013 chassis?
You certainly can , fitted one to my 2013 last weekend.
The upper bevel box clamp needs a trivial mod to clear the rear bulkhead, Phil will probably build this change into future kits.
Makes a world of difference for urban stop start driving with non of the clonk clonk we are used to with the NVH.
Is the purpose of this kit to get rid of bevel box whine or some of the other Driveline noises
kirkusblog.com
1952 Ford 8N
Bunny Offline OP
In my case the reason for fitting this kit is to eliminate the banging on acceleration. My BB is fairly quiet so I'm not too concerned with other noise issues. Phil's website goes into greater depth about the various other potential issues caused by the NVH system and in any case is an excellent read!
Andy
