3 members (Ian Wegg, hillclimber, TBM), 198 guests, and 86 robots.
+8Rich 80
DaveW 51
Topics49,866
Posts837,595
Page 2 of 10 1 2 3 4 9 10
Hi Coach Will,
Sounds like a fantastic journey!
Suggest, quality rain gear. The best 12 volt air tire pump at Harbor Frieght and a small battery tender I use a Sears. Check the oil level in the rear bevel box at the orange oil fill cap on the side. You will need a squirt bottle and fill very slowly to do it correctly. I used Red Line Extreme. Last but most importantly modify to a stage 1 exhaust as you will be facing the hot summertime temperatures! If your M3W has exhaust wraps remove them. Here is my Stage 1 conversion and it has worked very well and sounds really good!
http://www.talkmorgan.com/ubbthreads.php...ays_#Post442461
Another suggestion, I don’t think there too many US Morgan dealerships ( good to know each one) however there are a lot of custom hot rod shops and speed shops all across the country. Most of these guys would welcome you and are “get-ur-done” kind of guys.
Good luck and I’m here in Baltic, Ohio if your heading through on the beautiful two lanes!
My Blog: https://ontheroadtonowhereville.wordpress.com/
Todd
High Noon Speed Shop
when the M3W was first announced, I thought how wonderful it would be to do exactly what you are planning. I hope you have a fantastic trip!
Originally Posted By rockabilly john
If it has not been done, swap out the S&S rectifier for the Harley unit.
Peace of mind.
John.
Do NOT do this on a 2017 car.
My 2016 is perfect with almost 10,000 miles. Have a lust of every M3W dealer with you. No spares, just a cell phone, credit card and a smile. I can spend all day on my BMW R9T, but after a spirited hour in my M3W I need a 😴.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
I
I
I recommend a small scissors jack and battery powered compressor for fixing flats. I did a trip last summer and used the compressor once, the rear tire valve core was simply loose (check them before you leave)
Inge
Great advice, Todd! Many thanks!
Will do. Thanks, Hannes!
I plan on these! Thanks!
Terrific. Thanks!!
Great advice, John! Will do this.
Thanks, Calum! I am making a list. This is great!!
