1 members (Marmota), 391 guests, and 45 robots.
+8Rich 93
Posts837,276
Page 2 of 20 1 2 3 4 19 20
For all you people who may be interested in doing some work on your M3W's engine this will be a big help:
https://www.dropbox.com/sh/83mtpjd4eyra6vl/AABObO_2mLLAfURDrpQktuBRa?dl=0
Planenut thanks for that. Could I ask that you put a date on the list & that you highlight any changes or additions in future lists.
Tim
Tim
Good idea Tim, I will do that with the next update. Not been deluged with any more information from others, I cannot have it all surely?
WW11 MOG
WW11 MOG
Bloody Brilliant Ian - just what I need for doing my barrel to crankcase gasket replacement joy
Great undertaking Ian. Comparing my own modification list here are a couple of items that could be added to that section on yours.
B-G racing steering wheel spacers are available in a variety of depths from Demon Tweaks and likely much cheaper than Morgan dealer sources. Probably only suitable for standard wheel though.
I used a 25mm one. Click above for source. You will then need appropriate longer length M6 button head screws.
G56 bonnet fastener ejector spring kit as well.
https://www.garage56.co.uk/product/morgan-bonnet-fastener-ejector-spring-kit/
Links here for latest parts manual v5.2 in pdf format.
https://www.4shared.com/get/H-5MmbB8ei/M3W_Parts_Book_V52.html
or as individual images which can be used to illustrate a particular issue. You will need to choose page and click on download button on right.
https://www.4shared.com/account/home.jsp?sId=fd2cIXcQAf2XAZJg&changedir=hwPJPDi0
Hi Ian,
A few additions from me:
Long life Rectifier bobbins - https://caterhamparts.co.uk/mounts-gaskets/1075-exhaust-mounting-bobbin.html
Hex exhaust bobbins - https://www.clampcouk.co.uk/exhaust-repa...ing-bobbin.html
(Note, these need the stud on one side trimmed to fit)
To remotely disconnect the battery when not using the car for a few weeks and if you don't have access to a trickle charger - https://www.batterybrain.co.uk
Stick on Union Flag badges - http://shop.morgansportscarclub.com/acatalog/Union-Flag-Enamelled-Badges.-Stick-on.-32.html#SID=10
Punctureseal - http://www.punctureseal.com/
"Glovebox" storgage bag, easily mounted on passenger side but will need to be ordered via USA - https://dowcopowersports.com/willie-max-take-along-windshield-bag-large-58011-00/
Cheers
Chris
Red Leader drive
Thanks for the details above, I will add it and do another list soon. For info, the Morgan Three Wheeler Club website now has a section for the "5 Speeder", if you click on the "About" tag on the home page it is there. I have put a lot of info on that as well and it is all easily accessible. You don't even have to be a member to access it, although I am sure you all are..... The MTWC is embracing the "5 Speeder" much more now, worth joining if you are not in it.
Hi Ian
You have obviously put a lot of work into this and it is a wealth of useful info.
Book marked in my favourites.
Best regards
Keith
