9 members (IcePack, Montegue, JohnHarris, Graham, G4FUJ, TBM, Image, RichardV6, bmgermany, John V6), 373 guests, and 43 robots.
+8Rich 92
Posts837,278
Page 4 of 20 1 2 3 4 5 6 19 20
Lack plug leads from magnecor
They are there, about 3/4 down the engine section, including specification.
Seems to me this Most Valuable thread would be a sticky topic as it's of value to everyone with a 3W.
Late 2012 M3W
Planenut another one for your list:
Track rod ends comfort kit:
Fluro GIXSW14x1.5 Rod End Bearing 14mm Bore M14x1.5 Thread Female Right Hand
from ABC bearings.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Another one for the list - a 3mm x 72mm R clip is an easier to use replacement for the rear axle cotter pin.
Red Leader drive
And another one..
replacement bolts for the front mudguards in stainless steel
SS m8 x 16mm hex head with SS m8 shake proof washers internal serrated type
Kays on EBay
PaulR
Thanks for those additions. Next issue will be out soon. Any more information to add gratefully received, don't keep it to yourself.
Also...
The wooden 'spanner' for 2 eared wheel nuts works well instead of bashing the hell out of them with supplied hammer
...from MWS the wheel supplier
PaulR
A quick one - replace the tyre valve dust caps with ones with a gasket. These will hold pressure if the valve fails
EG:
https://www.befr.ebay.be/itm/TYRE-ALLOY-...4-/261355892387
Red Leader drive
