0 members (), 309 guests, and 87 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
#496968 01/02/18 03:08 PM
RobP Offline OP
Not sure if every 5 speeder is the same, but it seems to take a few seconds of the engine turning over for them to start.
I used to have a Harley, and always gave it 2 "pumps" of the throttle before starting.
Anyway, I tried it on the Morgan the other day and it started much more quickly. give it a go and see what you think!
1928 Superaero Jap 3 wheeler
2013 5 speeder 3 wheeler
RobP #496975 01/02/18 03:32 PM
Have you changed out the battery, yet? The stock battery is on the low end of what can fit on that car. I replaced mine with a Delco unit that had a third more cranking amps. That helped greatly!
Michael H #496994 01/02/18 04:46 PM
Particularly in this cold weather mine takes 2 or 3 goes to start, cranking for 5 to 10 seconds each time, and I have an uprated battery. But once started it will start instantly. Pumping the throttle is not recommended it confuses the throttle position sensor (I think)
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
RobP #496999 01/02/18 04:55 PM
They definitely don't like waking up in the cold - mine needs cranking for a good 10 -20 seconds if the temperature is low single figure degrees outside. When it does catch it's normally one cylinder intermittently then keep on cranking until the second chimes in.
As Roger said, don't pump the throttle - it has absolutely no effect on the fuel system but throttle position does feed into the ECU.
It's worth noting that the ECU will only let the car start if the throttle is closed. If it's open the car will crank but not fire.
Red Leader drive
RobP #497004 01/02/18 05:14 PM
I have heard from a Euro 4 M3W owner that his was particularly difficult to start in the cold, with the added bonus of the headlights being on as soon as the ignition was turned on, a extra battery load. The standard Banner battery wasn't up to it and was replaced with a higher CCA (Exide AGM?) and the ECU re-programmed to give a richer mixture from cold. Starting much improved. As others have mentioned, pumping the accelerator isn't a good idea as it confuses the ECU.
RobP #497007 01/02/18 05:32 PM
I don't pump the throttle either but pump the pump
ie turn the ignition on and off 3 times listening for the pump each time then pause say 5 secs then start
this usually works very well for me...
PaulR
RobP #497008 01/02/18 05:33 PM
+1 Paul
RobP #497032 01/02/18 08:05 PM
I
I
I began having trouble on a hot re-start last summer. Ambient temps were not that hot, ie in the 70F - 80F range. 8000 miles on the car, happened all of a sudden at a gas station.
Inge
planenut #497036 01/02/18 08:13 PM
CBM Offline
Have you been able to compare the performance and running of his Euro 4 (when it can start) with the Euro 3?
Inge #497071 01/02/18 11:05 PM
Did it happen after filing up with gas? If you fill to the brim it can cause starting and cutting out for a few miles.
Red Leader drive
