Topics49,918
Posts838,248
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 1,038 Likes: 36
Posts: 1,038 Likes: 36 |
The potential pitfall of restoration is the cost versus how good the restoration actually is ie wether its done correctly and at a sensible price. The is a massive industry out there as we know and its not straightforward regaring value for money. The figures can be crazy !! No wonder some restorations are carried out in far away countries now . You're absolutely right, I've seen more bad restorations than good ones. And then there's the question - what is a "full restoration" ? In my opinion it means taking the car back to its component parts and returning everything back to "as built" condition (and hopefully better.) That includes dismantling and rebuilding all mechanical and electrical components, including the gearbox and differential for example. To do the job to that extent is a costly exercise and for the majority of cars it doesn't make financial sense. My car still needs completing and a few details correcting but I'm certainly looking forward to seeing it completed, as is my bank manager ! Regarding the Jaguar restored cars, I've also spoken to a marque expert who confirms that they're not as "sharp" as they should be. Unsurprisingly it will take time for them to get the correct levels of knowledge and expertise in place.
Posts: 37,492 Likes: 994
Posts: 37,492 Likes: 994 |
Thanks for the progress pictures, it is looking a great car in the making.
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Hi everyone,
Really interesting thread and by shear coincidence I was at my brother in law's place yesterday and he was dismantling an etype back axle assembly (differential, dive shafts etc etc).
His car is undergoing a complete nut and bolt rebuild (lucky boy is in the trade) using original parts and panels he squirrelled away years ago.
Seeing it in stripped down state left meI in awe. And the weight of that diff!
I'd love one.
Regards
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 1,943 |
The XKE is a lovely car to drive. Don't do too good a job restoring it or You will be afraid to drive it. I am lucky, I get to drive a Friend's XKE so long as I take Her (The Owner) with Me. NO PROBLEM!!!!!!! Actually, in the Summer, along with Her +4 it is Her daily driver.
Button
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
Some more pictures. Looks a lovely job Just be aware that water will run down the inside of the membrane and leak out or pool between the door and the membrane. There are supposed to be deflect shields inside the door above the apertures, you may well have these fitted but very rarely are
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Just be aware that water will run down the inside of the membrane and leak out or pool between the door and the membrane. There are supposed to be deflect shields inside the door above the apertures, you may well have these fitted but very rarely are I know what you mean. It's surprising how many "restorations" don't even have the membrane fitted let alone the drain shrouds.
Posts: 12,269 Likes: 324
Posts: 12,269 Likes: 324 |
The use of these door membranes has always mystified me somewhat. Obviously they are not there to protect the door, so therefore I had always assumed they were there to protect the inner face of the door card and its leather covering. If that's the case, why did they never simply put the membrane on the inner face of the door card rather than on the door? Or is there another purpose that I'm not familiar with? On the cars that I've owned in the past (admittedly none of them top-rank stuff like this E Type) whenever I've had to get to the window winder mechanism or whatever I've removed the membrane and waterproofed the inside of the door card instead with no apparent ill-effects. Not suggesting that this should be done in a proper restoration, just interested in the original logic of using the membrane.
I think you're right Tim. They present a waterproof barrier that both protects the door card and also stops water entering the car.
I suppose if it was just stuck to the door card it wouldn't be a complete seal and there would still be a possibility of water leaking onto the carpets etc.
Yes there are the drain aids at the bottom under the door but also shields within the door. rarely seen, I used some more membrane on the inside of the door.
As it happens water is leaking in by the pedals somewhere.. urgh
