1 members (Socalm3w),
305
35
Posts837,277
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
With the roof down on my +4 SS I am aware of exhaust fumes entering the cockpit to some extent.
Didn't get that with 4/4.
Has any body else experienced this ?...might it be the air flow behind the car causing this?
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Overfuelling from the throttle bodies, leading to lots of VOC's at the rear ??
Posts: 1,616 Likes: 1
Posts: 1,616 Likes: 1 |
I have this on my M16 plus 4. It seems better with the side screens on. It does detract from the driving pleasure.
John 1992 plus4 connaught green
I am going to fit a wind barrier behind the seats but this would not sit well with an out and out track car.
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
I think that no spare wheel causes more low pressure at the rear. Peter J has talked about having stuff sucked into the cockpit area.
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
It was a problem on my Brooklands Roadster 3.7 but it has been solved by converting the exhausts to side exit. I'm guessing a vortex at the rear of the car brings the exhaust fumes into the cockpit. Image from a previous post  Don.
Posts: 2,519 Likes: 320
miles of smiles Talk Morgan Expert
Posts: 2,519 Likes: 320 |
Side exit exhaust and no spare here, no fumes with or without sides.
The air flow at the rear does seem to suck dirt back into the car though, there can be a slight film of grime on the slope and the back of the seats when the road is damp.
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
It was a problem on my Brooklands Roadster 3.7 but it has been solved by converting the exhausts to side exit. I'm guessing a vortex at the rear of the car brings the exhaust fumes into the cockpit. Image from a previous post  Don. How did you do it? I'd like something similar. I can definitely smell the exhaust coming in when the engine is cold so ai imagine it's doing it all the time, I just can't smell it once the cat starts working..... Nick
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Out and out track car and you worry about fumes? Not enough castor oil smell?
Posts: 5,587 |
Side pipes are definitely the way to go , have had no fumes.
