7 members (Davetherave, Alan Patterson, RichardV6, TBM, SailingTom2, Paul F, Mick Annick), 220 guests, and 21 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,123
Georgie Offline OP
I've now replaced the followers and Cams, see Re: Zetec-Replacing camshaft on this forum.
The car started up fine with just a little tappet noise, I revved up and held the revs at 2000+ for the recommended 20 minutes. On dropping back to idle I noticed a pronounced ticking.
I started the engine up again this morning, no ticking but when warmed up the ticking became quite loud.
Any clues anybody?
Are you sure you got the timing correct? I had similar on a Peugeot 16v engine, turned out to be a bent valve after a botched cambelt change (not by me!) Ran perfectly with good compression on all the pots though!
Arwyn
