1 members (Silverlady), 323 guests, and 38 robots.
John V6 69
+8Rich 66
DaveW 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Topics48,345
Posts813,037
Captain Morgan, IRWIN
Our Skoda was attacked by a rubbish collection lorry and the front passenger window looked so horrendous that my son was almost in tears because he was in possession of the car at the time. However I set to work with wire wool , cutting polish, toothpaste and t-cut. It all came out . Then I dropped the wire wool, picked it up, gave the last bit a little rub and made it ten times worse as there must have been grit in the wool! In the end after another hour or so of work it has just about disappeared but I was so cross with myself.
Mark P Offline OP
Thanks to all for the advise - will try out the options
Never seen in non green
I had the same problem on my +8, the previous owner had kept the wipers going with a missing blade. I could see the scratch and feel the scratch with my finger nail. I used the kit from Frost, basically a polishing wheel to use in an electric drill and some cerium oxide powder. This worked well, although it can be a bit messy. Unfortunately Frost are out of stock of the kits at the moment. Faced with a similar problem on another car I bought a kit through ebay. The scratches were a bit deeper and I had to use an abrasive pad before I finished with the cerium oxide. Took a while, but again it worked OK. The kits do mention that you need to use a mains powered drill, as they suggest the battery powered drills do not have the necessary power, or longevity. On ebay just search for 'deep scratch remover, glass polishing kit'. Try the powder first and then use an abrasive disk if the powder isn't man enough. You will then need to finish with the powder.
Mike Smith
2007 +4
I used jeweller's ruby polishing powder, some water to make a paste, and a buff on a hand drill to polish some light scratches from the windscreen of my Alfa.
