5 members (howard, PaulJ, davewhite, IcePack, Alan Patterson), 345 guests, and 82 robots.
Topics49,849
Posts837,410
DazMog, The Impaler, tlchzj79
Perhaps I have an audible speed limiter, other than MrsW screanming.
Originally Posted By Jono
Fixed neoprene tape all the way round head lamp, Re fitted and lamp now feels tight in bright work casing and you can’t see tape. Just took for test run and whistling gone totally. Thanks very much for fix.
Cheers,
Jon.
It's not a fault. It was fitted like that so as to make an ultrasonic whisle to deter kangaroos. They do have a nasty habit of suddenly jumping out in front of cars. You'll now have to be really careful around kangaroo feeding time, dusk and dawn are the worst times!!!!
Black Rat
Black Rat
Don't get a lot of Roos in Essex laugh2
Keith
2013 narrow bodied + 4 Ruby.
- the deterrent is working then!
thumbs
I had the sound on my 2018 Plus 4 as well. MMC only used about two inches of rubber tube glued on top of the headlamp, which is clearly not enough. It takes about material worth an extra pound to solve the problem on both headlamps and "insulate" them all around. Done!
Originally Posted By Roger Tapley
Dave that's probably young ladies above trying to get your attention.
laugh2
I imagine that the pitch of the whistle increases with the speed?
This opens up a whole new concept of tuning a Morgan!
innocent
Bud
4/4 "Stanley"
The pitch seems reasonably consistent but the volume varies.
Had this on a 4/4 about 15 years ago & I never cured it because I was convinced it was the slots in the folding windscreen brackets causing it, it was probably the headlights but no one tipped me off all those years ago
