10 members (Dougie, Robbie, Strathaven, JohnHarris, Chris Cosher, MATTMOG, Socalm3w, Hamwich, Liam1961, +8Rich),
234
74
Topics49,877
Posts837,735
Posts: 37,438 Likes: 983
Posts: 37,438 Likes: 983 |
The rear springs on my car always used to knock/tap on the plywood healboard when loaded. The springs pass through a little cutout in the healboard and would regularly make contact, even after I fitted brand new springs. That could save some people a lot of effort and money  .
Posts: 5,466 Likes: 171
Posts: 5,466 Likes: 171 |
My 4/4 Anniversary from March 2012 was thought to be at the end of the weak spring era. My 4/4 was Dec-13 - Jan-14 build and had weak rear springs? Maybe they found a leftover pair at the back of stores....... Would not be a surprise!
Posts: 314 Likes: 3
Posts: 314 Likes: 3 |
Raised the car today and took a look under it. The only suspicious spot I've found is this:  Since there is also an impression on the leaf spring, it looks as if it is striking here. What will it be like when we're on the road with our luggage?
Michael 2018 Plus 4 Sport
Posts: 1,705 Likes: 35
Posts: 1,705 Likes: 35 |
Yes that looks to be the contact point on the heelboard. Mine used to contact there on both sides. Could be quite scary sometimes.
Roger 2011 Plus 4
Posts: 314 Likes: 3
Is this something to worry about?
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
When I changed the rear springs on my 2012, I added a couple of strips of neoprene to dampen the knock. But with new springs it never recurred. Yours only looks to be catching very slightly.
Is this something to worry about? IMO I think it is dangerous. The worst scenario for me was driving on what appeared to be flat straight roads at say 60 or 70mph. Very occasionally if the road had a very specific but benign dip or undulation that coincided with what appeared to be a critical speed it would result in a huge suspension crash that would take you completely by surprise. Very scary.
Roger 2011 Plus 4
Posts: 3,825 Likes: 69
Posts: 3,825 Likes: 69 |
When I changed the rear springs on my 2012, I added a couple of strips of neoprene to dampen the knock. But with new springs it never recurred. Yours only looks to be catching very slightly. What would happen if you filled the gap with a wedge shaped block of wood? Would that shorten and therefore stiffen the springs? Nick
Posts: 1,943 |
Why not cut the plywood a bit to make room for the spring.
Button
Posts: 27,822 Likes: 749
Posts: 27,822 Likes: 749 |
It is a new car take it back to be fixed
