1 members (Graham, G4FUJ),
418
49
Topics49,841
Posts837,318
Posts: 86 |
Mine also had the improved cover for air circulation.
0000oooooooo
Posts: 136 |
Still can't get the belt back on! i assume that it goes over the left and center cam gears, under the left side idler, first. Then does it go over the right side cam gear or does it go over the tensioner and piñon pulley? when does the right side idler get installed?
I've been practicing with the old one as I don't want to mess up the replacement. Is any "persuasion" required with levers? The tensioner is fully released and I can barely get the belt to clear the 2" pin holding the right side cam gear in place.
Thanks!
1959 4/4 - sold 1957 +4 - sold 2017 M3W - sold
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
I've been practicing with the old one as I don't want to mess up the replacement. Is any "persuasion" required with levers? The tensioner is fully released during the fitting.
Thanks! On my car (2012) the belt track is shown on the reverse side of the timimg cover ?
Posts: 136 |
Thanks! i On my car (2012) the belt track is shown on the reverse side of the timimg cover ? It's on mine too. The issue isn't the belt track, it's trying to get the belt over the pulleys when the tensioner is fully retracted. Almost like the belt is too small.
Posts: 136 |
Got it in. Needed that 3rd hand. Thanks everyone!
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
My timing belt has 24k plus miles on it. I have carried a spare belt and the tools to change it for 3 years now. I have a Confederate motorcycles clear cover and the belt still looks good. I have to wonder about the wide differences in longevity. S&S recommends a change at 30k.
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
My timing belt has 24k plus miles on it. I have carried a spare belt and the tools to change it for 3 years now. I have a Confederate motorcycles clear cover and the belt still looks good. I have to wonder about the wide differences in longevity. S&S recommends a change at 30k. I believe the differences come down to heat. When my first died, without benefit of the cooling gap in the cover, it showed definite symptoms of blistering on the back of the belt where it would stop on the main crank shaft when the engine stopped. They always stop in the same place just like any 4, 6, or 8 cylinder block. That place was were my belt parted. Ever since I've had the gapped cover there has been no sign of blistering and this belt has outlasted the first by a significant margin.
Posts: 136 |
My car is a 2017 with the vented cover. The belt has less than 1100 miles on it. I've spent only about 5 minutes total in stop and go traffic and never driven when the air temp was over 80 degrees F. I suspect that it's a quality control issue with the belt.
Posts: 365 |
I am finishing up my cam upgrade and struggling a bit with getting the belt back on. Do you put both idler pullies back on before you route the belt around? I have the belt on but left off the one idler pulley with the lip to the front but having a very hard time to get the idler pulley back on with the belt on.
2017 M3W Sport Green
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
A couple of months ago I had my belt changed at the car's 3k service. It had lots of cracks on the outside skin as JP describes above. It was sent back to Morgan at their request, presumably for further investigation or claim against S&S. Best get these belts checked regularly...... My M3W is a late 2016 Good advice Ricardo...
