0 members (), 307 guests, and 43 robots.
+8Rich 93
Posts837,277
#509057 17/04/18 04:30 PM
SteveH Offline OP
Hi guys. I’m just about to start my first diy service on my 2014 +4 2.0ltr GDI . Anybody out there got part numbers for : oil and air filters. plugs . I assume Ford standard parts.
Thanks looking forward to a reply.SteveH and Harry
Stingmog
SteveH #509143 18/04/18 07:57 AM
Where is SteveT when you need him. I have a Duratec engine so don't want to give you duff info. When my car was serviced I looked up the code number on the Internet and got a whole list of alternative oil filters.
On my car I need to specify a filter with a bypass, anti drain valve.
Ian
SteveH #509147 18/04/18 08:09 AM
Well I'm about! Its going back a bit but when I did mine I used a K&N Oil Filter, from memory it was HP-1002, but easy enough to check the Ford to K&N cross reference.
Air Filter I didn't need and plugs were Ford, although again unless your mileage is high they may not be needed. Worth taking them in and out just to make sure they stay removable, most dealers don't bother because of high change intervals.
SteveH #509206 18/04/18 04:04 PM
SteveH Offline OP
Thanks Ian and Steve T. I’m trying to involve Harry in the service. Took a plug out to cross ref.- no luck. Emailed Williams -no reply. I’ll try Melvin Rutter tomorrow. Looking forward to PRESCOTT as the weather improves. Hope to see you soon.
Stingmog
SteveH #509211 18/04/18 04:28 PM
Breakfast Club this Sunday Steve? smile
SteveH #509275 18/04/18 08:26 PM
Unfortunately I cannot make Prescott, as have 1st grandchild S christening to go on.
Ian
I'm sure you'll have a great day Ian thumbs
SteveH Offline OP
Unfortunately as you know we were not there. We were taking part in the MAC classic run to Shelsley ( run up the hill included ) However we did call in to Prescott on the way and spied a couple of Mogster friends and of course big waves to you on the Ashford T/L,s. Harry was very excited. See you soon Steve
Stingmog
SteveH #510044 24/04/18 07:41 AM
I should have stopped briefly Steve as there was nothing behind me. smile
Would have got tongues going in the other vehicles, no doubt!
Good to spot you and Harry, all the same.
SteveH #510634 27/04/18 10:08 PM
Steve H
Re GDI servicing, please be very careful when removing the leads from the coil packs. You can damage them with resulting pain to the wallet and, unless you have done around 40,000 miles, there should be no need anyway.
Reg
