8 members (Clipper, Robbie, Alistair, linklaw, Morganmike, gaston, JohnHarris, DaveW), 309 guests, and 37 robots.
+8Rich 92
Topics49,837
Posts837,288
Page 3 of 12 1 2 3 4 5 11 12
2Sharp #509373 19/04/18 02:41 PM
When I spoke to Stuart E from Krazy Horse at RFTH 2016 he suggested that these are not necessary unless you go even further with tuning and start to look at the 128cu.in barrels etc. This was reiterated by their tech Dan when visiting their dyno last autumn. I don't doubt feedback that suggests smoother running, but they are probably not cheap and I'm not sure I want to go further on my car.....
Having said that, I am easily swayed if any more of you report smoother high-rev running and other tangible benefits!
2Sharp #509409 19/04/18 05:09 PM
Thanks for the insight's again nippymog. nothing beat's experience......
Come on Phil its only money and time :laugh2
I think they work out at about £400 ish...
2Sharp #509427 19/04/18 05:59 PM
I will dig out the invoice later ( making tea ) , but I am sure I paid way less than £400 - bear with as they say
2Sharp #509432 19/04/18 06:57 PM
notworthy
2Sharp #509434 19/04/18 07:15 PM
I stand corrected , £304 including the vat form Matts.
I still think its worth the money , especially when compared to some of the Morgan upgrades I have taken.
I am not bitter eek
2Sharp #509452 19/04/18 09:48 PM
cheers
2Sharp #509456 19/04/18 10:25 PM
Is the engine still "zero interference" with the increased lift? I.e. when the cam belt breaks, can a valve hit a piston?
Late 2012 M3W
2Sharp #509459 19/04/18 11:13 PM
Roller rockers in themselves are non interference - its when you go to the high lift cams ( which I think are part of the stage 3 Morgan kit ) you potentially get interference between valves and pistons.
I am sure this is all detailed on the S&S web site , or was a couple of years ago
2Sharp #509460 20/04/18 12:33 AM
Yes, agreed. The OP mentioned the rollers he chose increased lift, i.e. had an increased ratio over stock (likely 1.60 vs 1.50 which is typical). I was wondering if the increased lift afforded by these particular rockers caused an interference issue.
Late 2012 M3W
2Sharp #509462 20/04/18 02:43 AM
2Sharp Offline OP
Anyone have an idea what stud puller/installer I need to use?
2017 M3W Sport Green
